Just want to share my 914 project, Sheridan body, v8 project NOT, Subaru EG33 |
914pipe |
Sep 15 2008, 04:38 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Just some update on my ongoing slow proyect, 4 years by now. Too little time.
Here are som pics. Enjoy (IMG:style_emoticons/default/beer.gif) This is the base color.... planning to paint it in dark charcoal gray. Attached thumbnail(s) |
914pipe |
Sep 15 2008, 04:39 PM
Here some more....
914pipe |
Sep 15 2008, 04:41 PM
Last ones by now.....
tronporsche |
Sep 17 2008, 02:45 AM
Member Group: Members Posts: 281 Joined: 21-August 08 From: California Member No.: 9,447 Region Association: Central California |
Very nice ! I only looked at this thread. do you already have your rims, what do they look like ? Can't wait to see it when it is done.
jd74914 |
Sep 17 2008, 06:39 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
The car looks awesome! I really like the rear fender mod. (IMG:style_emoticons/default/smile.gif)
jc914 |
Sep 17 2008, 06:44 AM
Member Group: Members Posts: 289 Joined: 15-September 08 From: Miami, Florida Member No.: 9,548 Region Association: South East States |
Its looking very nice I like how the rear end looks
So.Cal.914 |
Sep 17 2008, 06:46 AM
Don't mind Jim, he got up early... (IMG:style_emoticons/default/biggrin.gif) When I first saw those lights, well...I wasn't a fan. But I must say with the body mods and paint they are looking pretty Tits. (IMG:style_emoticons/default/smile.gif) Power Plant? |
jd74914 |
Sep 17 2008, 06:54 AM
(IMG:style_emoticons/default/laugh.gif) Fixed. Nah, I've been working for a few hours writing a fascinating paper on the electro-chemistry behind fuel cells. . .
So.Cal.914 |
Sep 17 2008, 07:01 AM
(IMG:style_emoticons/default/laugh.gif) Fixed. Nah, I've been working for a few hours writing a fascinating paper on the electro-chemistry behind fuel cells. . . (IMG:style_emoticons/default/biggrin.gif) So how long until we have a H2O = 2xH x 0 = power supply? |
jd74914 |
Sep 17 2008, 07:23 AM
Err 2*H + O? Not very soon (if ever from non power-critical or fleet vehicle applications ). Too energy intensive/expensive to crack water, though the Army is working on some high temp cells that can run off of junk methane (they pollute though).
At work all H2 is cracked by hydropower at Niagra Falls which is a pretty neat/clean alternative. Anyways, hyjack over. |
wbergtho |
Sep 17 2008, 08:09 AM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
I haven't read this thread all the way through...but here is my question. Are you planning on blending the old headlight door into the rest of the body work (to the front bumper and to the outside of each headlight door). Consider doing this...because otherwise it will look like the twin light packs will revolve around or flip up and down. Blending will create a cleaner look as well.
Bill |
LarryR |
Sep 17 2008, 08:24 AM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
I am curious about 2 things: 1) are the headlights aim-able within the housing? If not it seems that the way you trim them could lead to headlights pointing off one way or the other. 2) what size (diameter) are the individual reflectors? seems like part of that unit could be grafted onto the existing headlight door for a factory look with out all the cutting and shaping (When I try to modify something to fit it usually looks like it was done by a second grader!) 1) check this video, they are already fixed, they have screw for adjustment and already test them. http://www.youtube.com/watch?v=AAfEjAERWuM 2) I dont have the car here right now but they are about 2" 1/2 Hope this help. That is pretty sweet! What transmission did you go with? The engine sounds healthy. |
wbergtho |
Sep 17 2008, 03:42 PM
I spoke too soon. I have dial up and your pics took a long time to load up. Now I see what you've done to the headlight area. Looks real nice. I also like the rear intakes you made into the Sheridan quarters. Very nice. I did a similar treatment using modified 996TT intakes. What kind of V-8 are you putting in...and how much HP. What trans are you using? Keep posting your progress. It is coming along very well. It took me about 7-8 years to get as far as I have and it still isn't complete. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/welder.gif)
736conver |
Sep 17 2008, 03:51 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
I spoke too soon. I have dial up and your pics took a long time to load up. Now I see what you've done to the headlight area. Looks real nice. I also like the rear intakes you made into the Sheridan quarters. Very nice. I did a similar treatment using modified 996TT intakes. What kind of V-8 are you putting in...and how much HP. What trans are you using? Keep posting your progress. It is coming along very well. It took me about 7-8 years to get as far as I have and it still isn't complete. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/welder.gif) Hey that yard looks familiar. Wait that pic was takin at my house. Alot of those guys make the grass turn brown with the hot engines. My neighbor thought they were all oil leaks. (IMG:style_emoticons/default/biggrin.gif) |
914pipe |
Sep 22 2008, 04:36 PM
Very nice ! I only looked at this thread. do you already have your rims, what do they look like ? Can't wait to see it when it is done. Sorry did not reply earlier.... About Rims..... What I have now are Mesh BBS from a 930. 15x9" in the front, 15x 11" on the rear. But I'm not gonna stick with those wheels.... Planning to use those for soloracing / A/X |
914pipe |
Sep 22 2008, 04:54 PM
Rear wheels.... not the best picture.
nuther As for the power plant, is a 350, .030 pistons. Here's a pic during build. Stock transmission, it has been very difficult to find one here in the island and don't have a good contact in the continental US. My only resource by now is the evilbay. (IMG:style_emoticons/default/shades.gif) That's it for now. Later will show my HomeDepot Racing cable shifter..... he he he (still working on it) (IMG:style_emoticons/default/aktion035.gif) |
914pipe |
Oct 10 2008, 09:39 PM
You some update. My friend painted the hood. This is how it looks.... venting trough the hood.
Sorry about the pics (crapy celphone) (IMG:style_emoticons/default/shades.gif) Attached image(s) |
914pipe |
Dec 29 2008, 10:56 PM
Today I decide to do some work on the hood vent. I took and old cotton shirt and some clamps to make a mold for the future hood vent tunnel?
I Attached the shirt to the radiator fan with some screws. Used the clamps to stretch the shirt and maintain the form I wanted. I applied some marine resin (the one u use for wood, was the only thing available around). I hope this work. Otherwise I would have to use the fiberglass resin or maybe BONDO? BTW I have to paint the hood again because Im going to do more mods, since I dont like the look, so I dont care right now about if the paint get damage. I will let you guys know later how its going. Hope this help for new ideas to the watercooled engine swap guys. Some pics |
plymouth37 |
Dec 29 2008, 11:24 PM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/aktion035.gif) Nice job, you are building one heck of a wicked ride!
jcambo7 |
Dec 29 2008, 11:54 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/smilie_pokal.gif) This is going to be one rockin 914 (IMG:style_emoticons/default/aktion035.gif) I love what you did with the headlights. They look great. And the sheridan looks real nice too. The eng sounds great and looks great. I cant wait to see what this car looks like when you are finished. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
Lo-Fi Version | Time is now: 18th April 2024 - 06:26 PM |
