| scottb |
Dec 14 2003, 01:44 PM
who wants a PEZ?! ![]() ![]() ![]() Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
what is the secret to putting the boot back on at the back of the firewall where the shaft exits the passenger compartment? it wasn't on properly when i bought the car and now that i have swapped out bushing i want it hooked up. i taught my kids a number of new words today while trying to get that damn thing on... (IMG:style_emoticons/default/headbang.gif)
there has to be an easy way i didn't think of. enlighten me please.... (IMG:style_emoticons/default/pray.gif) and now i will drink my beer and await your reply.... (IMG:style_emoticons/default/beer3.gif) |
| rhodyguy |
Dec 14 2003, 01:51 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you have to slick it up a bit, soap?, i use glycerin. hook the top first, stretch it a bit and try and roll it on . i sort of turn it l/r to help walk the seal over the lip. one of those time havig 3 arms would help.
kevin |
| scottb |
Dec 14 2003, 02:12 PM
thanks kevin. i tried turning the boot end inside out and flipping back over on the lip. no go.
this will wait for another day. perhaps the fact it was about 35F in the garage made a difference? and by the way, it is snowing to beat hell! |
| SirAndy |
Dec 14 2003, 02:15 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,488 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you don't happen to have a early car that was converted to side-shifter, have you?
in that case, the later boot won't fit and will just dangle around there. Andy |
| scottb |
Dec 14 2003, 02:22 PM
i have a 73 but the boot does just dangle there......
| SirAndy |
Dec 14 2003, 02:26 PM
QUOTE(scottb @ Dec 14 2003, 12:22 PM) i have a 73 but the boot does just dangle there...... hmmm, if i'm not mistaken there were a few '73s that were shipped with a tailshifter tranny. or was that '72? pics of the subject would help. (IMG:style_emoticons/default/wink.gif) Andy |
| rhodyguy |
Dec 14 2003, 02:32 PM
is the plate on the firewall round or a large oval? my guess is it's to damn cold. can you hang a trouble light near it to warm it up? a 35 deg garage makes for toasty fingers. if you put the car in 3rd it helps.
kevin |
| scottb |
Dec 14 2003, 03:57 PM
not under the car now but memory says a round plate on the firewall. my drop light is flourescent so no heat. (IMG:style_emoticons/default/headbang.gif)
was gonna grab the wifes hair dryer but she decided that was a bad idea.... |
| Brad Roberts |
Dec 14 2003, 04:24 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I put the bottom on first and stretch it towards the top. The bottom is hard to do because it is so close to that "lip" where the firewall and floorpans come together. Dont be afraid to bend the lip out of the way. You can bend it back when you are done.
B |
| campbellcj |
Dec 14 2003, 04:52 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,716 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
It also is one of those things that is much more of a beotch to work on without a lift. Lying on your back on the cold, oily concrete, it is tough to get a good enough grip on that little sucker. BTDT.
| Aaron Cox |
Dec 14 2003, 05:02 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
that boot saved my butt. the cone screws backed out while driving. i manually set the car in second gear (at the tranny) and limped it home (rolling thru stopsigns (IMG:style_emoticons/default/unsure.gif) ). that boot kept the screws in it.....just had to tighten em up and use some loctite (IMG:style_emoticons/default/smile.gif)
| EdwardBlume |
Dec 14 2003, 05:29 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
BTDT- not fun.... I did what Brad said to do. I also heard that you can heat the bushing up (boiling??), but haven't tried it.
| john rogers |
Dec 14 2003, 06:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Brad nailed it right on, you do the bottom first then slip the top over the flange. I tried for years to do it on my back, belly and side but a lift is just about mandatory. I guess you could have a deep hole to stand in too? Good luck
Lo-Fi Version | Time is now: 3rd August 2026 - 06:49 AM |
