What grade gas do you use?, In your teener |
KENNY |
Aug 18 2012, 06:47 PM
Member Group: Members Posts: 142 Joined: 5-February 03 From: Orlando fl. Member No.: 243 Region Association: None |
For the past 13 years I use premium . Never had a problem whit my car .
914Bryan |
Aug 18 2012, 07:43 PM
Member Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
I run 91 octane with a little Marvel in tank. The premium gas is to avoid any possibility of pinging and the Marvel is to keep the valves clean. I have heard that the premium fuel does not contain any methonal in it and some lower grades do. I am not an expert with this, but that is what I have seen labeled on the pumps. With old fuel systems I think methonal in any amount is taboo. Just my opinion.
iamchappy |
Aug 18 2012, 08:40 PM
93 nothing less for the turbo teener
rnellums |
Aug 18 2012, 08:44 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Back in 2007 when this thread last came up I was running 91. Now I'm still running 91.
euro911 |
Aug 18 2012, 11:40 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I've read that newer computer-controlled FI engine management systems may take up to three tanks of fuel to fully adjust to optimum settings, not sure about early 70's technology?
I use to run 87 in both of our [stock] 914s, but run mid-grade in the recently built 2056 (9:1 CR). I agree, you can run a low grade but avoid pre-detonation, and watch your temperature readings. If you change the grade of fuel, be prepared to readjust your timing (and jetting if running carbs) to account for the difference. |
Ian Stott |
Aug 19 2012, 04:13 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I don't want to use the ethanol enhanced fuel so I use high test which is around 91 octane where I live, the regular 87 octane does have the ethanol and I really want to stay away from that stuff. The extra few cents per litre is worth it to me, just for piece of mind, I want to go for a trouble free drive, not worry about what's in the tank. I find a lot of the older mechanics all use 91 octane, they feel it is the better way to go, sometimes experience is a good indicator even though they may not have graphs and computer printouts to back up what they are saying.
Ian Stott Moncton Canada |
brant |
Aug 19 2012, 11:58 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I believe with current US emissions (especially california)
all grades of gas should now have ethanol if I am wrong then good for you but I know in Colorado this is true and all grades of gasoline have ethanol. I thought this was the federal standard in the currently required, subsidized, energy and fuel plan that Mr. Bush left for us when he signed it into law in 2007. So the question really is about what grade of fuel your motor and octane require I don't believe there is any way to avoid the ethanol (not methanol as one poster mentions) |
JamesM |
Aug 19 2012, 12:34 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
You have to search to find it but if you are lucky you can still get ethanol free gas.
I run 92 Sunoco (etahanol free) when i feel like driving to the other side of the valley to get it. If I don't (or cant) get all the way over there to get it ill run 87,88 or 89 depending on what the station has. |
brant |
Aug 19 2012, 12:45 PM
You have to search to find it but if you are lucky you can still get ethanol free gas. I run 92 Sunoco (etahanol free) when i feel like driving to the other side of the valley to get it. If I don't (or cant) get all the way over there to get it ill run 87,88 or 89 depending on what the station has. and I would guess that one station that you use for ethanol free, probably has a label right on that pump that states it is not legal for highway use. I think they are selling it as an "offroad use" fuel if I could get it, I would do the same. maybe with the draught someone in washington will realize they need to repeal this law. Although I doubt the corn growers would feel that way. |
jsayre914 |
Aug 19 2012, 01:30 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I am running 91 in my 2056, I also use mystery oil in every other fillup.
Runs like a champ (IMG:style_emoticons/default/driving.gif) |
914Bryan |
Aug 19 2012, 02:43 PM
I believe with current US emissions (especially california) all grades of gas should now have ethanol if I am wrong then good for you but I know in Colorado this is true and all grades of gasoline have ethanol. I thought this was the federal standard in the currently required, subsidized, energy and fuel plan that Mr. Bush left for us when he signed it into law in 2007. So the question really is about what grade of fuel your motor and octane require I don't believe there is any way to avoid the ethanol (not methanol as one poster mentions) Ahhh! My bad, meant ethanol....Hanging out at the drags too much! (IMG:style_emoticons/default/blink.gif) |
euro911 |
Aug 19 2012, 04:02 PM
Ahhh! My bad, meant ethanol....Hanging out at the drags too much! (IMG:style_emoticons/default/blink.gif) ... and sniffing too much methane? (IMG:style_emoticons/default/poke.gif) |
Ian Stott |
Aug 19 2012, 04:04 PM
The 91octane pump (high test) says on it "ethanol free", the 87 octane pump (regular) says it contains 10 or 15% ethanol, I'm not sure which as I don't use it, maybe it's the law in Canada that they have to post the info. I used to run the refuelling section at Canadian Forces Base Greenwood in Nova Scotia and have had a few courses re. fuel, not just gasoline. I agree you only need to run the octane required for your engine not to knock/ping, but I have been running the 91 since the ethanol thing and like I said in a previous post, all those old mechanics that actually tear engines apart are running the 91. I know if I use a corner store gas bar of no name gas it isn't the same as Shell Gold, so that is what I use in all my vehicles.
Jeffs9146 |
Dec 4 2012, 06:42 PM
I voted for 91 but I am running an 83sc 6 and from what I have read they bumped up the HP to 204 with all the smog/exhaust stuff! I have since removed all that and added headers. The specs on the later 80 to 83 sc's said to use 91!
eyesright |
Dec 4 2012, 06:46 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
You can buy a fuel tester on line, but I bought mine from the local Briggs and Stratton parts shop for $8. I test the fuel now and then when I buy gas for the lawn mower. The pump sticker says "contains up to 10% ethanol" but I haven't found any alcohol content here in OK for a couple of years and lately the stickers have disappeared at many stations. A few of the Fina -- now Alon -- stations here have a pump for 100% regular and another for 10% ethanol regular.
And I just bought 3 testers for Christmas gifts for fellow enthusiasts. And you can make one with a test tube from your kid's chemistry set. Anyway, my 914 and '86 911 run fine on regular. And I like MMO a couple of times a year. It smells better than the other stuff, but its all "petroleum distillates" which I think usually means fuel oil, jet fuel, diesel, kerosene, etc. |
jersey914 |
Dec 4 2012, 08:30 PM
Member Group: Members Posts: 161 Joined: 6-September 12 From: Marlton, NJ Member No.: 14,895 Region Association: North East States |
Premium........it's a freaking Porsche.....Come on people
BTW, I run Marine stabilizer in every tank too......Ethanol is not our friend |
'73-914kid |
Dec 5 2012, 12:06 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Premium........it's a freaking Porsche.....Come on people BTW, I run Marine stabilizer in every tank too......Ethanol is not our friend Just because it's a Porsche, doesn't justify running expensive gas. If it doesn't ping on 87, run 87. the quality of gas does not improve as the octane increases, unless there's an increase in ethanol content as the octane goes down. Plus, 914's have vw engines... (IMG:style_emoticons/default/poke.gif) No need to spend extra for wasted octane... |
zymurgist |
Dec 5 2012, 09:29 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
2.0 D-jet, 87 octane
billh1963 |
Dec 5 2012, 10:07 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I've tried everything from regular to super unleaded. I never noticed a difference. Just use regular now
Ductech |
Dec 5 2012, 06:06 PM
Member Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region |
I drive a conversion in a conversion that's wrapped up like a Taco Bell double decker turbo death burrito...
So premium is required. Know your overal pressures your dealing with. High comp will require it. Most stock type 4's properly tuned could run happy on regular forever.i imagine when you consider the compression ratio and quality of gas at the time of manufacture. But as I've made an ass of myself before.. I could be totally off. |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:14 AM |
