New views on hydraulic cams., Dare I bring it up?!?!?!?! |
jk76.914 |
Jul 15 2007, 06:24 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Well, I have this hydraulic cam in my engine. And last fall I committed to making it work, and so now I have an update.
I'm hoping I won't get called a moron again! But here I go! This will probably be done in 3 parts- lifters, pushrods, and rockers. So I got convinced that the real issue with hydros is lack of adequate lube to the rocker boxes. I found a website that was discussing major problems with Lycoming (4 cylinder, air-cooled aircraft engines) when they transitioned to hydraulics in the late 70's. That was about the same time VW and Continental (aircraft) transitioned. VW had very similar problems, but Continental was virtually trouble-free. Many (all?) of the Lycoming problems can be explained by their implementation of hydros as opposed to the well known fact in 914 circles that hydos are, in fact, evil. In the article, it is observed that the hydraulic lifter has two roles- 1.) to adjust to changes in engine tolerances due to wear and temperature and keep the valves at zero lash, and 2.) to convey oil up the pushrods so as to lube the rockers. Inadequate oiling means inadequate cooling, stuck valves (due to oil coking on the stems), broken valves, bent pushrods, galled lifters and cams, etc, etc, etc... sound familiar? sound evil? How about valves failing (shattering) in flight? In the article, the authors go on to "point out a major shortcoming of the Lycoming design that we believe substantially accounts for valve train problems including stuck exhaust valves, prematurely worn valves and guides, and camshaft distress and failure." The early implementation in Lycoming (and VW?) focused on the first role and missed the second. I'm open to correction, but I think this was the VERY first use of hydraulic valve actuators by VW. Anyway, here's the article: http://www.prime-mover.org/Engines/Marvel/tbo3.html Every time I read it I get something more out of it.... It also touches on sodium filled valves... On my own engine, I noticed that when I adjusted the hydros to +.006" (clearance) and then idled it, there was significant oil flowing out and all over my driveway. (This in spite of the fact that I installed a half valve cover to catch oil.) When I then adjusted to -.006", the flow virtually stopped- the pushrod seated in the rocker like a valve in its seat. I re-read the article, and then started at the lifter. I bought three brands of T4 lifter- Meyle, Febi, and Isky. I disassembled them and looked at the various schemes of metering oil to the head. Meyle Febi (may be the same as Sealed Power) Isky (may be made by Delphi?) Both the Febi and the Isky have a metering disk beneath the pushrod seat that meters oil from the plunger to the pushrod. The Meyle relies on oil leakage around the pushrod seat and then into the side hole and then through the pushrod seat to the pushrod. This does not seem to me to be a reliable way to forward oil up the pushrod. Also, there is a reference to two designs of VW hydraulic lifter at this article- http://www.ratwell.com/technical/HydraulicLifters.html . In the article, Richard Atwell speculates that VW improved the design because it changed from having a paper clip style retainer to having a circlip retainer to hold it all together. Well, Meyle (questionable oiling) has a paper clip style retainer, and Febi (improved oiling) has the circlip. My theory is that VW migrated from Meyle to Febi, because the Meyle was causing failures due to inadequate lube. It's all anecdotal and speculative, but for the life of me I can't imagine how the Meyle can reliably and predictably convey oil to the head..... (beating the same dead horse) Meyle, Isky, Febi oil metering to pushrod. In addition to the article on Lycoming and Continental, I looked closely at Corvair (freakin' Chevy to some). 1.7 million Corvairs were built over a 10 year period, and all had hydraulic lifters. And they were never considered a reliability issue. The Corvair is basically a six cylinder Type 4 (though Corvair predates T4 by almost 10 years). So I also purchased 2 Corvair lifters- one used original Chevy and one new Sealed Power. Upon disassembly, I found oiling similar to the Isky and the Febi- both have a method of metering the oil, as opposed to relying on leakage. When GM discontinued the original Corvair part number, there was quite a bit of activity on the internet about substitutes and how effective they are in transferring oil to the rockers, so clearly it's a more openly understood requirement with the Corvair-meisters than with us T4 guys whose starting point is solid lifters...... (one of these days I'll get around to taking photos of the Corvair lifters) So anyway, after I was satisfied with which lifter I would use (I stuck with my Iskys, thought I wouldn't hesitate to use Febi either), I moved on to the pushrods.... and I'll get into that in my next post, probably in a few days.... |
MecGen |
Jul 22 2007, 07:03 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hah
I knew you were a hightec type of guy (IMG:style_emoticons/default/drunk.gif) I have never realy looked deep into the swap at this level but...pretty sure the hydrolifters run a completely different spring rate... (IMG:style_emoticons/default/confused24.gif) and if your running unregulated oil preasure (modified oil releif), maybe just some food for thought... Worst comes to worst...just shoot it into space... (IMG:style_emoticons/default/ar15.gif) Later (IMG:style_emoticons/default/beerchug.gif) |
jk76.914 |
Jul 22 2007, 10:05 AM
Hah I knew you were a hightec type of guy (IMG:style_emoticons/default/drunk.gif) I have never realy looked deep into the swap at this level but...pretty sure the hydrolifters run a completely different spring rate... (IMG:style_emoticons/default/confused24.gif) and if your running unregulated oil preasure (modified oil releif), maybe just some food for thought... Worst comes to worst...just shoot it into space... (IMG:style_emoticons/default/ar15.gif) Later (IMG:style_emoticons/default/beerchug.gif) The engine oil pressure only ensures that the lifter fills with oil. It does not actually lift the valves. The pressurized oil is forced into the chamber below the plunger. When the lifter begins to ride up the cam lobe, it tries to collapse. This closes a check valve- either a ball or a disk- on the bottom of the plunger, which traps the oil in that chamber. The oil is not particularly compressible, so the lifter looks and acts like a solid lifter now as it rides up the cam lobe. So, why would you need stronger springs? Stronger springs help keep the lifter in contact with the cam as the valve closes. especially at increasing RPM. There's a lot of inertia to move- valve, rocker, pushrod, plus lifter- and not much time to move it all. If all this mass can't keep up with the cam, the whole valve train becomes unloaded, and there's a risk that the lifter will self-adjust to a longer length. Then, when it finally crashes into the cam, it may have adjusted enough to hold the valve open. So there's about a 5500 RPM performance limitation on hydros. (Ron Iskenderian told me that I should be good for 6000, but I never exceed 5500.) Some SBC suppliers make claims of 7000 RPM but I'm skeptical. As far as loading the heel of the cam during "normal" RPMs- The engine oil pressure acts on the plunger to keep a slight load on the valve train at all times. The diameter of the plunger in my Isky lifters (Johnson) is .670". That's an area of .3526 square inches. Thus, at 40 psi, the force on the heel of the cam is .3526 x 40 = 14.1 pounds. That's at 40 psi, at lower RPM it's proportionately lower. I assume the cam lobe is evenly hardened, and so the heel is as hard as the top, so I can't imagine wear of the heel ever being measureable compared to the wear at the top, where the forces are probably 10x that (I don't know, but it's the valve spring constant x the lift). So in my view, you may be better off having an operational oil pressure relief (opens at 45-50 PSI I think) to unload the oil pump at high RPM and reduce the load on the engine. At any rate, having it there or not doesn't seem to make much difference conceptually to me in terms of whether your hydros are going to work or not. |
Lo-Fi Version | Time is now: 7th May 2024 - 12:48 AM |
