> New views on hydraulic cams., Dare I bring it up?!?!?!?!
jk76.914
post Jul 15 2007, 06:24 PM
Post #21
Well, I have this hydraulic cam in my engine. And last fall I committed to making it work, and so now I have an update.
I'm hoping I won't get called a moron again! But here I go! This will probably be done in 3 parts- lifters, pushrods, and rockers.
So I got convinced that the real issue with hydros is lack of adequate lube to the rocker boxes. I found a website that was discussing major problems with Lycoming (4 cylinder, air-cooled aircraft engines) when they transitioned to hydraulics in the late 70's. That was about the same time VW and Continental (aircraft) transitioned. VW had very similar problems, but Continental was virtually trouble-free. Many (all?) of the Lycoming problems can be explained by their implementation of hydros as opposed to the well known fact in 914 circles that hydos are, in fact, evil. In the article, it is observed that the hydraulic lifter has two roles- 1.) to adjust to changes in engine tolerances due to wear and temperature and keep the valves at zero lash, and 2.) to convey oil up the pushrods so as to lube the rockers. Inadequate oiling means inadequate cooling, stuck valves (due to oil coking on the stems), broken valves, bent pushrods, galled lifters and cams, etc, etc, etc... sound familiar? sound evil? How about valves failing (shattering) in flight?
In the article, the authors go on to "point out a major shortcoming of the Lycoming design that we believe substantially accounts for valve train problems including stuck exhaust valves, prematurely worn valves and guides, and camshaft distress and failure."
The early implementation in Lycoming (and VW?) focused on the first role and missed the second. I'm open to correction, but I think this was the VERY first use of hydraulic valve actuators by VW.
Anyway, here's the article: http://www.prime-mover.org/Engines/Marvel/tbo3.html
Every time I read it I get something more out of it.... It also touches on sodium filled valves...
On my own engine, I noticed that when I adjusted the hydros to +.006" (clearance) and then idled it, there was significant oil flowing out and all over my driveway. (This in spite of the fact that I installed a half valve cover to catch oil.) When I then adjusted to -.006", the flow virtually stopped- the pushrod seated in the rocker like a valve in its seat.
I re-read the article, and then started at the lifter. I bought three brands of T4 lifter- Meyle, Febi, and Isky. I disassembled them and looked at the various schemes of metering oil to the head.
Attached Image Meyle
Attached Image Febi (may be the same as Sealed Power)
Attached Image Isky (may be made by Delphi?)
Both the Febi and the Isky have a metering disk beneath the pushrod seat that meters oil from the plunger to the pushrod. The Meyle relies on oil leakage around the pushrod seat and then into the side hole and then through the pushrod seat to the pushrod. This does not seem to me to be a reliable way to forward oil up the pushrod.
Also, there is a reference to two designs of VW hydraulic lifter at this article- http://www.ratwell.com/technical/HydraulicLifters.html . In the article, Richard Atwell speculates that VW improved the design because it changed from having a paper clip style retainer to having a circlip retainer to hold it all together. Well, Meyle (questionable oiling) has a paper clip style retainer, and Febi (improved oiling) has the circlip. My theory is that VW migrated from Meyle to Febi, because the Meyle was causing failures due to inadequate lube. It's all anecdotal and speculative, but for the life of me I can't imagine how the Meyle can reliably and predictably convey oil to the head..... (beating the same dead horse)
Attached Image Meyle, Isky, Febi oil metering to pushrod.
In addition to the article on Lycoming and Continental, I looked closely at Corvair (freakin' Chevy to some). 1.7 million Corvairs were built over a 10 year period, and all had hydraulic lifters. And they were never considered a reliability issue. The Corvair is basically a six cylinder Type 4 (though Corvair predates T4 by almost 10 years). So I also purchased 2 Corvair lifters- one used original Chevy and one new Sealed Power. Upon disassembly, I found oiling similar to the Isky and the Febi- both have a method of metering the oil, as opposed to relying on leakage. When GM discontinued the original Corvair part number, there was quite a bit of activity on the internet about substitutes and how effective they are in transferring oil to the rockers, so clearly it's a more openly understood requirement with the Corvair-meisters than with us T4 guys whose starting point is solid lifters...... (one of these days I'll get around to taking photos of the Corvair lifters)
So anyway, after I was satisfied with which lifter I would use (I stuck with my Iskys, thought I wouldn't hesitate to use Febi either), I moved on to the pushrods.... and I'll get into that in my next post, probably in a few days....
jk76.914   New views on hydraulic cams.   Jul 15 2007, 06:24 PM
Dave_Darling   Interesting... IIRC, lack of rocker (and associat...   Jul 15 2007, 07:59 PM
McMark   Thanks! Looking forward to the rest of the ...   Jul 15 2007, 08:08 PM
914Sixer   Very interesting article. I just pulled apart a 1...   Jul 15 2007, 08:56 PM
jk76.914   Very interesting article. I just pulled apart a ...   Jul 16 2007, 05:09 AM
sww914   Very interesting post. Thanks for doing all the re...   Jul 15 2007, 09:43 PM
Jake Raby   A large portuion of the problem with Hydro equippe...   Jul 16 2007, 06:02 AM
Johny Blackstain   :popcorn: ! I am no mechanical engineer but ...   Jul 16 2007, 06:26 AM
jk76.914   :popcorn: ! I am no mechanical engineer but...   Jul 17 2007, 01:04 PM
jk76.914   :popcorn: ! I am no mechanical engineer but...   Jul 18 2007, 09:12 PM
Johny Blackstain   Forget to reply to the Mercedes injectors- they...   Jul 18 2007, 09:16 PM
Jake Raby   Yes, I have purposely neglected my engines for the...   Jul 16 2007, 06:44 AM
rjames   jk76.914, your timing is perfect. I have hydros i...   Jul 16 2007, 03:21 PM
Jake Raby   Loud hydros are usually due to oil pressure issues...   Jul 16 2007, 03:33 PM
jk76.914   Thanks for all the replies. I wanted to get into ...   Jul 16 2007, 07:14 PM
Bleyseng   Hell, I have always thought with the head half ful...   Jul 16 2007, 07:37 PM
jk76.914   Hell, I have always thought with the head half fu...   Jul 16 2007, 08:43 PM
Jake Raby   When all your oil ends up in the valve covers and ...   Jul 16 2007, 07:44 PM
jk76.914   When all your oil ends up in the valve covers and...   Jul 16 2007, 08:43 PM
jk76.914   Thanks for all the replies. I wanted to get into ...   Jul 16 2007, 08:39 PM
Jake Raby   One thing to consider is the fact that adding thos...   Jul 16 2007, 08:43 PM
jk76.914   One thing to consider is the fact that adding tho...   Jul 16 2007, 08:55 PM
Jake Raby   Solid lifters do not rely on oil pressure to funct...   Jul 16 2007, 09:01 PM
rjames   What weight of oil and type (synthetic or non) is ...   Jul 17 2007, 02:04 AM
jk76.914   What weight of oil and type (synthetic or non) is...   Jul 17 2007, 05:33 AM
Jake Raby   You need to change that oil every 3 months, even i...   Jul 17 2007, 08:43 AM
SGB   I use 20W50 Castrol changed every few months with ...   Jul 17 2007, 08:18 PM
morph   I have started to experiment with motors,and to ha...   Jul 17 2007, 11:26 PM
914-8   I did some similar research regarding hydraulic li...   Jul 18 2007, 10:15 PM
jk76.914   I did some similar research regarding hydraulic l...   Jul 19 2007, 04:58 PM
Jake Raby   My opinion is that having hydraulic adjustment imp...   Jul 18 2007, 10:18 PM
jk76.914   I'll try and finish up my brain dump tonight. ...   Jul 19 2007, 05:00 PM
jk76.914   OK, last installment. I know the lifter selection...   Jul 20 2007, 08:56 PM
MecGen   Hey Man....serious good work here ! :popcorn...   Jul 21 2007, 06:02 AM
jk76.914   Hey Man....serious good work here ! :popcor...   Jul 21 2007, 08:43 AM
Dr Evil   Very cool and concise write up, thanks! :thumb...   Jul 21 2007, 11:20 AM
Coy   I have a 2 liter with hydraulic lifters & tw...   Jul 21 2007, 05:58 PM
MecGen   Hah I knew you were a hightec type of guy :DRUNK...   Jul 22 2007, 07:03 AM
jk76.914   Hah I knew you were a hightec type of guy :DRUN...   Jul 22 2007, 10:05 AM
- Lo-Fi Version Time is now: 1st July 2025 - 03:50 PM
