> That's weird!, Tach drops 1000 RPM at 4K, but car drives fine . . .
anderssj
post Jul 23 2007, 02:20 PM
Dog is my copilot...
I took the car out last night for the first time in a few weeks. While it ran great, the tach needle dropped about 1000 rpm every time it got near 4K. Drove the car about 25 miles and tach never read higher than 3800 rpm. When I should have been seeing around 4200 in 3rd, I was seeing about 3000.
Odd thing--or the good thing--was the car ran great, no missing, no problems with driveability, so I wouldn't suspect points/condensor (yet).
I've already checked the coil, all the wire connections are tight. The coil bracket is tight too, so the coil doesn't rotate or allow the wires to ground out.
FWIW, I had the dashboard apart a couple of weeks ago. I drew a picture, labeled everything, and thought I had it back together correctly--but there's always a chance I screwed it up (Dad used to say I could screw up an anvil (IMG:style_emoticons/default/dry.gif) ). If anyone can tell me which wires go to which terminals on the bottom of the tach, that would be a big help (the terminal numbers on the tach don't match those in my diagram).
Thanks in advance for your help and insights!
anderssj   That's weird!   Jul 23 2007, 02:20 PM
Tobra   That sounds like a short to me, dirty contacts on ...   Jul 23 2007, 03:18 PM
anderssj   Thanks! I may try to pull the tach tonight ...   Jul 23 2007, 03:25 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 01:55 PM
