new problem: alternator on a 3.6 ... |
Jul 25 2007, 09:52 PM
Resident German Group: Admin Posts: 41,654 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so the clutch finally works, got it all back together this afternoon, drive home went without a problem.
i pull in and park the car and come back 10 minutes later, start her up and the alternator light stays on ... (IMG:style_emoticons/default/WTF.gif) rev her up, no change. turn her off and back on, same thing. i checked all the fuses, rotated them, no change. (IMG:style_emoticons/default/headbang.gif) now effin what? alternator on a 3.6 is internal. how do i check on it ??? (IMG:style_emoticons/default/confused24.gif) Andy |
drive-ability |
Jul 25 2007, 10:00 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
so the clutch finally works, got it all back together this afternoon, drive home went without a problem. i pull in and park the car and come back 10 minutes later, start her up and the alternator light stays on ... (IMG:style_emoticons/default/WTF.gif) rev her up, no change. turn her off and back on, same thing. i checked all the fuses, rotated them, no change. (IMG:style_emoticons/default/headbang.gif) now effin what? alternator on a 3.6 is internal. how do i check on it ??? (IMG:style_emoticons/default/confused24.gif) Andy Andy, You could start by checking the battery voltage to see if the charging system is exhibiting a problem. |
Dr. Roger |
Jul 25 2007, 10:12 PM
this thread may help. the last few postings are the applicable ones.
http://www.dorkiphus.net/porsche/showthread.php?t=7536 sounds like the exact same thing. |
McMark |
Jul 25 2007, 10:22 PM
Did you reconnect your ground cable? Just a random thought....
I'm inclined to think it has something to do with that new gauge, but I can't say what. |
Jul 25 2007, 10:27 PM
sounds like the exact same thing. nope. see, it worked *fine* all the way home. if it was missing an external resistor or diode or whatever, i would have had that problem from the beginning. i never touched the alternator. lights was off during my drive home. it wasn't until i restarted the car, that it stayed on. (IMG:style_emoticons/default/confused24.gif) Andy |
Jul 25 2007, 10:28 PM
Did you reconnect your ground cable? Just a random thought.... I'm inclined to think it has something to do with that new gauge, but I can't say what. yes, ground strap attached ... i took the old gauge with me. thank god i didn't hack into the harness, switching them out will be easy ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
McMark |
Jul 25 2007, 10:30 PM
it worked *fine* all the way home I debated even posting that because I knew you would say that. But I just gots a feeling. When it's all over we'll see who's right and who's not. (IMG:style_emoticons/default/tongue.gif) |
PRS914-6 |
Jul 26 2007, 01:00 AM
Andy, it looks like you just installed new gauges. Yes? The alternator light MUST work since that circuit is what excites the alternator. So if the alternator light is not making a circuit, or the bulb is burnt out or not hooked up, that is your problem.
Good luck..... |
Jul 26 2007, 01:28 AM
So if the alternator light is not making a circuit, or the bulb is burnt out or not hooked up, that is your problem. yes. i know. like i said, the light STAYS on. doesn't go out. meaning, the bulb works ... see, lighty worky ... (IMG:http://www.914world.com/bbs2/uploads/post-179-1185423657.jpg) (IMG:style_emoticons/default/biggrin.gif) Andy |
John |
Jul 26 2007, 10:50 AM
You did check your belt(s)?
McMark |
Jul 26 2007, 11:01 AM
Did you check the battery voltage running and off to see if there is a difference?
dakotaewing |
Jul 26 2007, 12:23 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Jul 26 2007, 01:56 PM
You did check your belt(s)? belt(s) are fine ... (IMG:style_emoticons/default/smile.gif) hey, i've got a reputation to uphold ... (IMG:style_emoticons/default/cool_shades.gif) Did you check the battery voltage running and off to see if there is a difference? here are the numbers, across the battery terminals: • 12.61 V - ignition off • 12.38 V - ignition on • 12.06 V - idle • 12.08 V - idle with gauge bulb disconnected, just for the giggles ... clearly, it's *not* charging ... (IMG:style_emoticons/default/sad.gif) Andy |
McMark |
Jul 26 2007, 01:58 PM
I don't remember, is the stock diode hooked up to anything?
Jul 26 2007, 02:03 PM
I don't remember, is the stock diode hooked up to anything? yes, stock diode is hooked up, but it's not for the alternator circuit. it's for the brake circuit. it's used because the brake warning light has multiple functions (parking brake, master cylinder, seatbelt interlock and emergency flasher) ... (IMG:style_emoticons/default/bye1.gif) Andy PS: to clarify, there's a diode in the alternator circuit on early cars, but i have a '74 main harness ... |
MartyYeoman |
Jul 26 2007, 02:08 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Can, or did, you check the voltage regulator?
Jul 26 2007, 02:09 PM
Can, or did, you check the voltage regulator? i wouldn't know how, it's all internal ... (IMG:style_emoticons/default/confused24.gif) Andy |
Jul 26 2007, 02:14 PM
alright, i need some strong coffee. i'm gonna drive her up to starbucks (about a mile from my house) and see what happens ...
got my AAA card with me ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Dr. Roger |
Jul 26 2007, 03:00 PM
My internally switched alternator has but one wire connected to it.
It is tickled by low voltage from the thick wire coming from the battery. Does yours use 1 thick wire or are there 2 or more wires? What model and year is your engine? |
Jul 26 2007, 03:26 PM
My internally switched alternator has but one wire connected to it. It is tickled by low voltage from the thick wire coming from the battery. Does yours use 1 thick wire or are there 2 or more wires? What model and year is your engine? i'll have to take the shroud off the motor to get a look. there's no easy access to the alternator. '95 993 3.6L motor ... (IMG:style_emoticons/default/smile.gif) Andy PS: leaving for starbucks, be back in a minute ... |
Lo-Fi Version | Time is now: 24th May 2024 - 01:00 AM |
