new problem: alternator on a 3.6 ... |
McMark |
Jul 26 2007, 04:04 PM
Uh oh, it's been 30 minutes. (IMG:style_emoticons/default/ohmy.gif)
Jul 26 2007, 04:33 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
yeah, yeah ... (IMG:style_emoticons/default/poke.gif)
now, riddle me this: after i got to starbucks and gulped down a double shotted espresso, i walk back to the car and fired her up. light stays on, like before. parking lot is empty, so i give it a "spirited" takeoff. and the damm light goes OUT !@*!! so i pull over and put the multimeter to the terminals: • 12.95 V at idle • 14.04 V at 3k rpm now it's working again ?!? (IMG:style_emoticons/default/WTF.gif) i suspect i either have a lose connection somewhere or the voltage regulator is on it's way out the door ... (IMG:style_emoticons/default/blink.gif) Andy |
John |
My internally switched alternator has but one wire connected to it. It is tickled by low voltage from the thick wire coming from the battery. Does yours use 1 thick wire or are there 2 or more wires? What model and year is your engine? i'll have to take the shroud off the motor to get a look. there's no easy access to the alternator. '95 993 3.6L motor ... (IMG:style_emoticons/default/smile.gif) Andy PS: leaving for starbucks, be back in a minute ... That's one of those jobs I would pull the motor for....... Like the clutch..... |
McMark |
Jul 26 2007, 04:49 PM
I seem to recall that a bad battery might cause this.... (IMG:style_emoticons/default/confused24.gif)
Jul 26 2007, 04:57 PM
I seem to recall that a bad battery might cause this.... (IMG:style_emoticons/default/confused24.gif) hmmmmm, it's 4 years old or so ... (IMG:style_emoticons/default/idea.gif) maybe i should swing by flaps and get a new one ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
geniusanthony |
Jul 26 2007, 05:32 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
In the interest of helping someone else out, I will admit my brain lapse with my -4's charging system.
After going through two new Optima redtops and swapping my OE alternator for a new one(which sucked) It took me a solid day of lookin and head scratching till I plugged the alternator lead back into the relay board. and Low and Behold she lived. I feel much better with that off my chest by the way. |
drive-ability |
Jul 26 2007, 09:50 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
Andy,
Before I dug in and removed anything I would just do some manipulation of the harness in the engine bay and any other related areas. Clearly its possible theres a skew some where that may show up. I would do it with the engine running so you can see any changes on the fly. Maybe have someone with there eyes on the dash or a dvom. I don't see hammering the throttle shaking loose an internal alternator problem but surely a wiring issue.. would be effected by vibration and engine twist. |
Lo-Fi Version | Time is now: 16th June 2024 - 09:48 AM |
