Brake question, Should there be fluid in the inner adjuster spot? |
swl |
Aug 1 2007, 08:50 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Changing the rear pads and when I took off the cap from the inner adjuster I got a little trickle of fluid. There are rubber seals down there right? Should that not keep the fluid back? Time for a rebuild?
skline |
Aug 1 2007, 08:53 AM
No, there should not be fluid coming out of there, yes, it is time for a rebuild. Nothing is more important than your brakes, never scrimp there.
swl |
Aug 1 2007, 10:15 AM
Thnks Scott. That's what I thought. Just wanted to make sure before I got all carried away.
I have a set that we rebuilt on the old car - I'll just mount those up for now. |
davep |
Aug 1 2007, 10:29 AM
That is correct, there should be no brake fluid back there.
If you need a full rebuild on a set, I can help. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:43 PM |
