Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I consider myself somewhat mechanially inclined, but I'm not quite sure what I'm getting into.
The story: My son drives his 1.7 over the pass to Redmond (about 150 miles), car has been runnign great, goes to leave last sunday, gets some gass on the way out. About 4 miles down the road car starts loosing power, sounds like it's not running on all cylinders. I had my father inlaw drive it over to a local shop that knows little about 914s, and have been told that the engine needs to be rebuilt. I have yet to talk to the shop, but this is the story I've gotten second hand, I'll be calling tomorrow. My thinking As it's not smooking, and it's not banging around like a valve dropped, is that it's down to air, fuel or spark Air- don't think this is an issue as it runs partially Fuel - could be an injector problem, but my son did mention that it backfires like ther was unburnt fuel in the exhaust, so I'm thinking it's probably spark. Spark- I was hoping that it was a plug wire grounding out and that the shop would check it, simple fix. It still may be that, or a plug that has broken. I plan to start the car and pull plug wires until there is no change when I remove one, If it's not the wire (I'm going to replace all) the pull plugs and replace. This is a stock 1.7, are there any other things I should be on the look out for? Any feedback is appreciated. Thanks, Mark (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 30th June 2025 - 10:16 PM |
