911 front suspension, Which ones are best and why? |
EMRoadster |
Aug 4 2007, 12:08 AM
Autocrosser Group: Members Posts: 65 Joined: 20-August 05 From: Tucson, AZ Member No.: 4,620 |
I've been searching and reading as much as possible and though I've seen references to 911 front suspesion conversions I haven't found any specifics on what year models are good, better, best and why. Does anyone have or know where on the internet it may already be? I'd like to find details as to what years, models, options, how to identify, and pros and cons of each one.
Thanks, Greg |
skline |
Aug 4 2007, 01:17 AM
I would go for the later years for the 3.5" brake spacing. Mine has a Carerra front end from an 80's 911 with the A calipers. My last one I went with an early model from the early 70's and the ball joints were different and the brake spacing was only 3" which limits the size of brakes you can run. They all work though, so it's just a matter of what you can find and what you want.
davep |
Aug 4 2007, 07:15 AM
It would probably be best to stick with 1974 and up (not sure how far, maybe 89). The very early ones up to 1968 can have pretty funky parts. From 1969 the 911 mostly had vented rotors with either 3.0" or 3.5" caliper bolt spacing. Avoid the 911E with the hydro-pneumatic struts (no torsion bars in A arms). So look for the 911S with the 3.5" spacing. The struts with the pinch bolt for the ball joint are not as desirable either, so that means about 1973 up. 1974 were almost all 911S (3.5") with the better ball joint. Try to get the whole front suspension (struts, brakes, A-arms, cross member, pan; steering rack optional and nothing after the rack itself is useful). Aluminum "S" or iron "A" calipers can be used, but the "A" is much less expensive. Early Turbo is essentially 911"S". From 1978 they get kind of funky with the super expensive 4 piston calipers. Early front vented rotors are 20mm thick, and the Carrera got the 24mm thick that can aid heat dissipation but would reduce acceleration in a low HP car. It also depends on the type of car you are building; built for street, autocross, track and what HP.
EMRoadster |
Aug 4 2007, 11:14 PM
It would probably be best to stick with 1974 and up (not sure how far, maybe 89). The very early ones up to 1968 can have pretty funky parts. From 1969 the 911 mostly had vented rotors with either 3.0" or 3.5" caliper bolt spacing. Avoid the 911E with the hydro-pneumatic struts (no torsion bars in A arms). So look for the 911S with the 3.5" spacing. The struts with the pinch bolt for the ball joint are not as desirable either, so that means about 1973 up. 1974 were almost all 911S (3.5") with the better ball joint. Try to get the whole front suspension (struts, brakes, A-arms, cross member, pan; steering rack optional and nothing after the rack itself is useful). Aluminum "S" or iron "A" calipers can be used, but the "A" is much less expensive. Early Turbo is essentially 911"S". From 1978 they get kind of funky with the super expensive 4 piston calipers. Early front vented rotors are 20mm thick, and the Carrera got the 24mm thick that can aid heat dissipation but would reduce acceleration in a low HP car. It also depends on the type of car you are building; built for street, autocross, track and what HP. Ok, depending on what I find it looks like the perfered choices are `74 and up. And from `78 up they could have either style calipers? What year and model did the Aluminum crossmember start? I still have to dismantle the recently accuired `74 I have to see how good the tub really is. Depending on what I find, the street project and the autocrosser project could end up swaping tubs. The street project plans are for a DD that will see ocasional autocross and maybe possibly a little track time for fun. It will be 2.0 turbo subaru powered with either a subie trans or one of the late 915's I have. The autocrosser will not be street legal but a dedicated autocrosser that may see some track time too. Current plans for power are a mildly built 5.0L Ford V8 at ~400HP, lots of tubing and hiem joints and 1850 to 1900 lbs w/driver. |
brant |
Aug 4 2007, 11:38 PM
[ Current plans for power are a mildly built 5.0L Ford V8 at ~400HP, lots of tubing and hiem joints and 1850 to 1900 lbs w/driver. Its really really difficult to get anything but a -4 to 1850 in fact its difficult to get a -4 to 1850 I'm at 1837 and it took 2 years of weekends to achieve that... a coupl of thousands of hours. there are a bunch of threads out there about the front suspension it was actually 1972 when they changed the ball joints, so your ok with going 72 and later. its a bit about money with small brakes you can probably do a full front end for 500 with the later bigger brakes it's closer to 1000 for the 500 difference you get marginally bigger calipers and an aluminum crossbar that is only marginally lighter (and some claim it flexes and actually deteriorates the handling) I personally don't buy into the flex arguement, but the point is that 500$ buys nothing you can feel seat of the pants. of course to actually reach 1850 your going to need every pound you can get |
rfuerst911sc |
Aug 5 2007, 07:32 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I am converting my 75 over to a /6 useing a 3.0 911 engine. I searched for a 911 front end and came across a 1972 that included strut housings,struts,calipers,rotors,hubs for 300.00 so I jumped on it. Yes it uses the 3 inch brake caliper spacing but my intent is street rocket, autocross monster and maybe a DE or two per year. The rotors are 20mm thick vented which are the same size as my 83SC and I have no problems with heat or fade on the heavier SC. Granted the SC has larger 3.5 inch calipers but still the same rotor. I think with todays brake pad technology and cooling setups I don't anticipate any problems with my setup. I am also going to use the 3 inch M calipers on the rear with a adjustable proportioning valve so I'll be able to take advantage of the M calipers all the way around. As stated earlier one advantage to the 1978-1989 strut assemblies is that you can use the 24mm thick Carrera rotors which give better thermal mass for cooling, the downside being they are heavier. (IMG:style_emoticons/default/beerchug.gif)
EMRoadster |
Aug 5 2007, 09:43 AM
I guess it's a good thing both projects are still in the planning stages. (IMG:style_emoticons/default/idea.gif)
Looks like the smaller 911 brake stuff will be great for the street project car but I may have to rethink some more things with the autocrosser project. Since in SCCA EM I'll have an 1850 lb minimum W/driver and in XP about 2300 lbs Without driver when using a 5.0L engine. |
Chuck |
Aug 5 2007, 10:25 AM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
EMROADSTER,
Brant is correct about the price of the front ends. In general the smaller setups run around $500 or so whereas the large brake setups tend to run around $1,000. The other thing to keep in mind, and this is advice that was given to me by Eric Shea, the resident brake guru, you can buy just the struts for around $150 if you are patient. You don't necessarily need the entire front end. That was what I had intended to do until . . . I happened to find a complete late 80's Carrera front end with the struts, calipers, rotors, aluminum cross member, sway bar and steering rack for $400 from a member here. I then found the matching rear calipers from an 86 Carrera with all new seals and brake pads on ebay for $150 along with the matching 86 Carrera master cylinder for $35. A set of rear rotors and Eric Shea's rear 5 lug converted trailing arms and I will be good to go. Moral of the story, if you are patient and a little lucky you can put together a nice setup for not a lot of $$$. Oh yeah, this is all intended for my '73 2.0 turbocharged subie project. |
Eric_Shea |
Aug 5 2007, 12:39 PM
Greg,
One thing I like to look at is the body, hence, what size tire can you fit. There comes a point where your tires and HP will overcome the potential of the brakes: Narrow Body - Basic M-Caliper struts from 69-73 MY 911T's. They have M-Calipers, vented rotors and can handle a plethora of replacement strut inserts. This is exactly what the factory 914-6 came with and is more than adequate in braking capabilities. These can be fairly easily coupled with the stock rears. A basic 1970 911T strut is my favorite for this conversion. Wide Body - Early Koni, Bilstein or later SC struts with 3.5" spacing. This will allow S-Caliper, A-Caliper, Early Turbo Caliper, Carerra-Caliper (A-Caliper with larger spacers) These brakes all have the same piston size as the M-Caliper however the pad area is larger. These should be paired with 914-6 rears or Ferrari rears for street use (handbrake) or 911 rear M-Calipers for track use. A basic 911SC strut is my favorite for this conversion (allows more insert capabilities). The later SC (Boge) struts with the 3.5" spacing should be a little more flexible with regard to inserts whereas Koni struts will only take Koni inserts and Bilstein struts will only take Bilstein inserts. I use Koni's on my cars but they are a little difficult to do any spindle mods on them (I'm testament that it can be done however). I like the trunk knob adjustability of a Koni. Bilsteins are easier to perform spindle mods on but you are set with the insert you get... it is however, one hell of an insert. (IMG:style_emoticons/default/wink.gif) |
strandron |
Aug 7 2007, 10:12 AM
Newbie Group: Members Posts: 7 Joined: 7-September 04 From: Oxnard CA Member No.: 2,713 |
I have an earlier 911 front end for my 76 914 , I want to use the 5 lug hubs and the ventilated rotors and the Bilstiens . The 911 calipers are toast but my 914 calipers are excellent it appears to me that the only difference in the two calipers are the little spacers used to spread them to fit the larger ventilated rotor. Could I rebuild my 914 calipers with these spacers and have them fit the 911 rotors ?
John |
Aug 7 2007, 01:09 PM
I prefer later model 911 BOGE struts.
There is a larger selection of inserts available for use with them. In fact, I believe that some 914 inserts can be made to work with them. I also prefer the later SC or later struts. They are newer and have the 3.5" bolt spacing for the larger calipers. Like most everything else, buy the latest struts in the best condition that you can afford. If you are on a budget and building a street car, some of the best deals can be found on the older 3" bolt spacing struts and calipers as most people want the 3.5" spacing. |
Spoke |
Aug 7 2007, 02:14 PM
Here's what $450 on ebay got me. 3.5in A calipers, struts, A arms, torsion bars, aluminum crossmember with horn attached, steering rack, underbody swaybar, 4-to-5 lug converted rear end (poorly done; hubs replaced by Eric Shea's nice ones), half shafts with CVs, and rear calipers.
Be patient and you will find a good deal on a 911 front end. Spoke Attached image(s) |
Eric_Shea |
Aug 7 2007, 03:45 PM
QUOTE I have an earlier 911 front end for my 76 914 , I want to use the 5 lug hubs and the ventilated rotors and the Bilstiens . The 911 calipers are toast but my 914 calipers are excellent it appears to me that the only difference in the two calipers are the little spacers used to spread them to fit the larger ventilated rotor. Could I rebuild my 914 calipers with these spacers and have them fit the 911 rotors ? No. Not the same size spacers. You could probably use the rear m-caliper spacers but you'd have to mill 3mm off them. Just get the 911 M-Calipers rebuilt. They have a slightly larger piston and should be perfect with the vented rotors. 3" is perfect for a narrow car. 3.5" is best for a flared car. |
crash914 |
Aug 7 2007, 07:07 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
anyone ever look at a 944 front end? It looks like more of them are available in junk yards... I saw at least 3 over the weekend...
scotty b |
Aug 7 2007, 07:18 PM
anyone ever look at a 944 front end? It looks like more of them are available in junk yards... I saw at least 3 over the weekend... They're wethless unless it is a turbo. N/A 944's have a single piston, floating caliper like most passenger cars, and light trucks. They do O.K. for a stock 944, but I personally HATE floating calipers. |
EMRoadster |
Aug 7 2007, 10:19 PM
I prefer later model 911 BOGE struts. There is a larger selection of inserts available for use with them. In fact, I believe that some 914 inserts can be made to work with them. I also prefer the later SC or later struts. They are newer and have the 3.5" bolt spacing for the larger calipers. Like most everything else, buy the latest struts in the best condition that you can afford. If you are on a budget and building a street car, some of the best deals can be found on the older 3" bolt spacing struts and calipers as most people want the 3.5" spacing. John, What do you consider to be late model? How would I tell the difference between a Boge, Bilstien and a Koni? Is it simply stamped on the outside of the strut housing? |
John |
Aug 7 2007, 11:25 PM
Sorry for the confusion.
My own personal thoughts of 911's ends with the 1989 model year. I know the air cooled cars continued on, but the suspension parts on the late 1989+ cars no longer bolt directly to our beloved 914's. So, I consider 79-89 late® model 911's (I know I am stuck living in the past, but I do drive a 914.) You can tell Bilstein struts because they are green (at least from the factory) The KONI struts were red/orange, and the BOGE struts were black. Yes they are stamped right on the strut. My street car uses Bilstein struts. They are a bit odd in the fact that the shock is upside down and the rod is pinned to the bottom of the strut. They are John Deere Green, and they are a bit bouncy, but they do seem to work. Our track car uses BOGE struts from a 930 and can use a variety of inserts (KONI, Bilstein, etc.) I believe we have adjustable KONI inserts in them and they work well. |
Richard Casto |
Aug 8 2007, 04:03 PM
...This will allow S-Caliper, A-Caliper, Early Turbo Caliper, Carerra-Caliper (A-Caliper with larger spacers)... Eric, Regarding A-Caliper spacers. What variations are there and why? I assume it is for different rotor widths. I initially thought that there would be a version with no spacer and a later version with a spacer. But with you mentioned above that the Carerra version of the A-Caliper has a larger spacer, that implies that other versions exist with smaller spacers. If they all have spacers is it that the caliper was an off the shelf ATE item and each customer (such as Porsche) would just use an appropriate spacer depending upon the rotor width? So what is the scoop? And what different spacer sizes are in use? I am personally interested as I just aquired some A-calipers and realize that I don't know which rotor they would match up with and maybe I can figure this out via the spacer size in the caliper. Richard |
Eric_Shea |
Aug 8 2007, 08:46 PM
QUOTE Regarding A-Caliper spacers. What variations are there and why? I assume it is for different rotor widths. I initially thought that there would be a version with no spacer and a later version with a spacer. But with you mentioned above that the Carerra version of the A-Caliper has a larger spacer, that implies that other versions exist with smaller spacers. If they all have spacers is it that the caliper was an off the shelf ATE item and each customer (such as Porsche) would just use an appropriate spacer depending upon the rotor width? Pretty much. I'm not sure if they're called A-Calipers but various BMW calipers are virtually identical with the A-Caliper castings except they are on a 3" spacing. They have the widows peak down the backside of the caliper which leads to a fluid inlet. The only difference I've seen on the BMW calipers is the fluid inlet is on one side of the peak or the other (depending, left or right) where the Porsche version of the A-Caliper has the fluid inlet at the bottom of the peak. There are some misc. casting differences but they look a lot alike. The BMW caliper does not use a spacer and can be bolted to a 914 (not a great idea but done widely). It has a 48mm piston and the same pad size as the A and S-Calipers. I'm not certain of the spacer sizes but the first one which is commonly referred to as the A-Caliper is for the basic 911SC and runs on the standard 20mm vented front rotor (the same rotor that came on a 914-6). The later A-Caliper, which some call the Carrera caliper, is the exact same caliper with a larger spacer to fit on the 24mm Carrera rotor. You should be able to tell what you have based upon the width of the rotor gap... standard A-Caliper should be 24mm |
Eric_Shea |
Aug 8 2007, 09:49 PM
Lo-Fi Version | Time is now: 15th May 2024 - 12:36 PM |
