1.7 running rough- can't figure it out |
Mikey914 |
Aug 15 2007, 01:01 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I just replaced the head as a result of the push rod shearing on #3, set clearance on valves starting at #1, counter clockwise 2,3,4 as per manual. hooked up plug wires and re installed. hooked up all the hoses, but it's running at a very high idle @1600. and it's running rough like a plug wire not firring. They are all in order, I checked spark on each, I checked all hoses are connected, and the idle control screw has no real effect.
When I apply throttle it chugs, but does increase RPM. What am I missing here, I could use a few other fresh brains. (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 02:45 AM |
