| mrhurtalot |
Aug 20 2007, 02:38 AM
VRRRRRRROOOOOOOOOM! ![]() ![]() Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
ive got my tranny back from the shop. and tommorrow ill be heading home from school to put it in.
ive tried last week, but it just would slide all the way on. i could get it on the bolts and it would get stuck about an inch or so from being completely on. the shop opened the case and replaced some stuff, do you guys think i just need to move the spindle around a bit? any tips will help alot. (IMG:style_emoticons/default/bye1.gif) |
| Joe Ricard |
Aug 20 2007, 05:58 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Correct throw-out bearing?
Are you using the alignment tool for the clutch disk is it the right clutch disk What does it seem to be interfering on? You could take the clutch off and see if it goes in then |
| jr91472 |
Aug 20 2007, 09:31 AM
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
With the trans in gear, try rotating the axle hubs a bit. Shouldn't take much, but just enough to rotate the "spindle" as you call it.
Should go on pretty easy, so don't force it. Sometime it can be a difficult to get every thing aligned (laying under the car, holding up a tranny, etc). Did you remove the clutch at all (you said tranny work, but didn't mention anything else)? If so, follow Joe's advice and make sure the clutch disk is aligned properly. good luck! |
| tdgray |
Aug 20 2007, 09:48 AM
Thank God Nemo is not here to see this ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,706 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
(IMG:style_emoticons/default/agree.gif) 99.5% of the time the clutch disk is not aligned properly. Happend to me a couple of times.
| mrhurtalot |
Aug 20 2007, 11:09 AM
is it not called a "spindle"? hmmm then i guess ive heard twenty people call it the wrong thing haha.
well i didnt touch the clutch or anything, throw out bearing had better be correct since i changed that like 3 months ago and it worked fine. ill try the clutch tool and rotating the stubs and get back to you guys. thanks for your help. it is very frustrating laying on the dirty garage floor lifting a heavy chunk of metal only to have it not fit in!! |
| davep |
Aug 20 2007, 11:32 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,352 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
BTDT. I find it much easier to pull the engine & tranny as a package to do that work. If nothing else it is easier on the motor mounts. Usually it is just an alignment problem. Try & try again. Rotate the flywheel a little each time.
| Joe Ricard |
Aug 20 2007, 12:43 PM
Jacks.
Last time I stabbed a transaxle to an installed motor without jacks I thought "that was stupid" I have a big sissor jack to support the engine. and then floor jack to hold most of the transaxle weight. once it gets to the 2 bottom studs it's all smooth sailing. Ya want tough? try a 928 transaxle. 150 pounds of whoop ass. |
| Cap'n Krusty |
Aug 20 2007, 12:51 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
The big trick is to support the tranny at the center of gravity so there's no "side loading" as you install it. Put it in a gear, and apply rotating pressure to BOTH stubs. Given enough force, the mainshaft will turn and align with the splines in the clutch disc, enabling the tranny to slide right in. Remember, no side loading of the components, and spline alignment. Piece 'o cake. The Cap'n
Lo-Fi Version | Time is now: 13th January 2026 - 12:05 AM |
