| JC 914 |
Aug 23 2007, 10:28 AM
Member ![]() ![]() Group: Members Posts: 124 Joined: 21-June 07 From: Johnson City,TN Member No.: 7,827 |
Trying to replace my interior light, but have no voltage with or without door switch. Any troubleshooting tips appreciated! (IMG:style_emoticons/default/headbang.gif)
| SGB |
Aug 23 2007, 10:33 AM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
its a switched ground (at the door switches and also the light fixture itself). The hot lead should be back there somewhere.
| JC 914 |
Aug 23 2007, 10:38 AM
| dr914@autoatlanta.com |
Aug 23 2007, 10:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,255 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Trying to replace my interior light, but have no voltage with or without door switch. Any troubleshooting tips appreciated! (IMG:style_emoticons/default/headbang.gif) up to 73 power comes from fuse 11 and 74 and up the interlock relay under the seat (this often corrodes) black with red lead. |
| JC 914 |
Aug 23 2007, 10:40 AM
Trying to replace my interior light, but have no voltage with or without door switch. Any troubleshooting tips appreciated! (IMG:style_emoticons/default/headbang.gif) up to 73 power comes from fuse 11 and 74 and up the interlock relay under the seat (this often corrodes) black with red lead. Thanks, Doc This is a '74 |
| retrofit |
Aug 24 2007, 01:04 AM
Member ![]() ![]() Group: Members Posts: 176 Joined: 17-April 04 From: Turlock,Ca Member No.: 1,943 |
Trying to replace my interior light, but have no voltage with or without door switch. Any troubleshooting tips appreciated! (IMG:style_emoticons/default/headbang.gif) up to 73 power comes from fuse 11 and 74 and up the interlock relay under the seat (this often corrodes) black with red lead. Thanks, Doc This is a '74 Did those tips solve your problem? I have a '74 with a center backpad light that has never worked. I'm going to try the black/red as a power lead. Just connect it as the hot lead? (IMG:style_emoticons/default/confused24.gif) Allen |
Lo-Fi Version | Time is now: 17th November 2026 - 05:05 AM |
