Getty 911 Dash Fitting Questio, Test fitting and wondering ... |
jim_hoyland |
Aug 25 2007, 09:00 PM
Get that VIN ? Group: Members Posts: 9,282 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The GD fit pretty good and I'm going to do some filing on the front. When fitting, there are two gaps. One is between the the rear of the GD and the dash frame--I have about 1 1/2 inch gap there. The second is between the face of the dash frame and the front edge of the GD--I have 1/2-2 inches there.
Right now, it appears the GD will attache to the original gauge hoop with the original screws and at the dash face ends. Any tips for fitting or things to avoid will be appreciated--I'm taking this real slow. Jim |
wbergtho |
Aug 26 2007, 09:30 AM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Just grind, cut, massage, add on, basically whatever it takes to make it fit correctly. I have one in my car and I remember it took a little work to make it all work. Are you covering it with anything? I did leather.
Aug 26 2007, 12:54 PM
Resident German Group: Admin Posts: 41,632 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
show me the gaps ... you have the lower windshield/cowl seal? (IMG:style_emoticons/default/idea.gif) Andy PS: here's mine, which i had to cut to clear the rollcage. |
Lo-Fi Version | Time is now: 12th May 2024 - 07:09 AM |
