Carb ?'s, I got IDF's w/ vacuum ports and chokes.. |
Dave Cawdrey |
Mar 17 2003, 12:14 AM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Anyone have ideas what to do? Plug ports? Use 'em? Choke is good in the morning, right?
Enlighten me, oh wise(ass) ones (IMG:style_emoticons/default/pray.gif) |
Dave Cawdrey |
Mar 17 2003, 01:54 AM
C'mon man? No help? You guys suck (jk (IMG:style_emoticons/default/tongue.gif) )
Do i need to go over to PP? JK, again LOL |
Brad Roberts |
Mar 17 2003, 01:57 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Plug the ports and forget the chokes. I have yet to see anybody install and route the cables needed to make them work..cleanly.
B |
Dave Cawdrey |
Mar 17 2003, 02:00 AM
What about using the e-brake or heater cable tubes for the cables? Prolly not using them
Brad Roberts |
Mar 17 2003, 02:05 AM
The heater cables would be perfect with the handle and everything... but it would be easier for you to adapt a 914/6 method that utilized a small handle much like the heater handle and used a rod to push on the accelerator pedal arm. It mounted in the front slot of the shifter.
The cables are too short from the factory heater lever. I'm not sure they would work well extended to the proper length. The angles needed to get to the carbs would be a little extreme. Look into the pieces that the 6 used. The early 911's with carbs used the same parts and all the shifters have the "slot" in them for the lever arm. B |
Dave Cawdrey |
Mar 17 2003, 02:10 AM
(IMG:style_emoticons/default/clap56.gif) Thats more like it . Thanks B-
john rogers |
Mar 17 2003, 12:01 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I used a pair of bicycle brake cables (inner and outer) and went to a bunch of trouble to hookup the chokes to the heater control lever and they actually worked. They dump in some extra fuel but it seems no additional air is let in so I finally unhooked them to get rid of the cables.
Brad Roberts |
Mar 17 2003, 12:41 PM
Thanks John,
I had NO idea they only added fuel. Sounds like the factory 6 kit would work for all the carbed cars running around out there. B |
SirAndy |
Mar 17 2003, 12:57 PM
Resident German Group: Admin Posts: 41,614 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
what about those "automatic" chokes they had on the VW?
you know, press the gas pedal down completely before starting the car will lock in the choke, and when the car warms up, it unlocks itself. could you get that to work on the 914 carbs??? (IMG:style_emoticons/default/smash.gif) |
Aaron Cox |
Mar 17 2003, 05:24 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
Hi all!
I am running dual 44 idf 's and they work fine! Nice throaty sound and breathe well going any where, and breathe extremely well when wide open and accelerating, loves to run at 2500 to rpm redline.....as for chokes, never hooked em up. i start my car by: giving two gas pedal pushes, (gets accelerator pump squirting some fuel ready to go), start the car an blip rpm's for 10 - 30 sec, (depending on temp outside) and then let the car warm up for a minute or two....no hurries! love the setup, but have a question as to how much airfilter one can stick under the rain tray? i am currently running them w/o stacks and short square airfilters (bought the vw bus kit - not a lot of airfilter clearance in there!) want to run stacks and some taller airfilters (round) any one have this setup? (IMG:style_emoticons/default/biggrin.gif) |
Aaron Cox |
Mar 17 2003, 05:26 PM
oooooooooooohh! just thought of something! what if you had two samll choke cables, and hooked em up too a small solenoid at the rear of the engine compartment? that would be sweet and super slick! (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/mueba.gif)
Lo-Fi Version | Time is now: 4th May 2024 - 08:06 AM |
