dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
I have all new shift bushings....
About 6 weeks old... My car was hard to shift at first... after a few weeks they were better Today the temp was 45. Hard to shift again. It has been 80-90 here everyday I drove this car since finished the build... Is this normal? Cold plastic bushings at 45-50 degrees much harder than 80-90 degrees? Hope nothing is wrong with car... Let me know what you think. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
bushings not lightly greased with white lithium, trans dope too heavy, not 80/90??? Trans rebuilt with syncro rings that are too pillowed.
Is the car grinding or just hard to get into gear? I have all new shift bushings.... About 6 weeks old... My car was hard to shift at first... after a few weeks they were better Today the temp was 45. Hard to shift again. It has been 80-90 here everyday I drove this car since finished the build... Is this normal? Cold plastic bushings at 45-50 degrees much harder than 80-90 degrees? Hope nothing is wrong with car... Let me know what you think. |
dflesburg |
just hard to move the lever.
It was fine on Sunday, but it was 93 degrees outside |
Lo-Fi Version | Time is now: 17th June 2024 - 02:02 AM |
