My 1st & 2nd 914, The project begins and is getting bigger by the hour |
my928s4 |
Sep 16 2007, 03:36 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
After working out a deal with Craig at Camp914 I borrowed a trailer and drove down to Portland and back yesterday with this 75 1.8. I think this is going to be a more solid foundation for my project than the last one I looked at.
Craig was excellent to work with and a wealth of information, I also bought some chrome bumpers that will eventually replace those rubber impact items. Figured I should just pick them up now and save myself the shipping hastles from somewhere later. I should have one of the other cars out of my garage in a week or so and then I will get this car up in the air and post some questions, although the car is in pretty good shape there are a couple of areas that need attention but it is a 30 year old car. Engine needs attention but that is on the list of things I had planned on doing anyway. Just let you guys know this forum has been great for gaining knowledge for a newbie. Cheers Chris |
my928s4 |
Sep 16 2007, 08:21 PM
Some observations and questions
Anyone guess what the black button does?? I worked at it for a while, turned on ignition and then it started the engine !! Presume the red LED is for an alarm or something aftermarket? There is a toggle switch on the fuse box also. Where is the odometer reset? Is there a dimmer for the instrument cluster? Chris |
ahdoman |
Sep 17 2007, 09:23 AM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Some observations and questions Anyone guess what the black button does?? I worked at it for a while, turned on ignition and then it started the engine !! Presume the red LED is for an alarm or something aftermarket? There is a toggle switch on the fuse box also. Where is the odometer reset? Is there a dimmer for the instrument cluster? Chris Hey Chris, When I got my car it also had the "starter" button. It basically bypasses the start position on the key. If you look under the car back where the starter is located (up behind rear left wheel, under the rear trunk ) you might also see a little relay intercepting the solonoid. That is a "hot start" switch system. Basically what someone did to your car (the same as a PO did to mine) is they decided to bypass the whole starter electrical circuit. In my case it was because some of the wires were hooked up wrong and fried. |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:51 AM |
