VW Badge location & body numbers, Challenge to determine beginning & end |
davep |
Sep 23 2007, 06:23 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I require help with my research.
Typically, the VW badge was riveted to the right headlight bucket up to the end of 1974 and made its way to the right upper corner of the fuel tank bulkhead in 1975. Also, the body number was originally stamped into the rear trunk floor and made its was to a black riveted tag on the support below the right headlight bucket, as well as being found on the Karmann badge. At some point the body number base changed from xxy95zz to xxy90zz. I require everyone to help with changeover VIN, and body number for each of the changes. Please add paint code and date code from the compliance decal as well. Attached image(s) |
davep |
Apr 9 2020, 10:21 PM
It has been only 13 years, but it is time to resurrect this thread so that new people can add new information. Two things that we are looking for: 1) VIN & Karmann # on the tag in the front trunk when it first appeared, or the last use of the rear trunk stamping. The Karmann # is also on the paint tag. 2) VIN & Karmann # on the tag in the front trunk when it changed from the base 9500 to base 9000. Paint tag and compliance decal photos also very useful. Do you have a CoA or window sticker? I need them also.
Lo-Fi Version | Time is now: 16th May 2024 - 06:10 PM |
