VW Badge location & body numbers, Challenge to determine beginning & end |
davep |
Sep 23 2007, 06:23 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I require help with my research.
Typically, the VW badge was riveted to the right headlight bucket up to the end of 1974 and made its way to the right upper corner of the fuel tank bulkhead in 1975. Also, the body number was originally stamped into the rear trunk floor and made its was to a black riveted tag on the support below the right headlight bucket, as well as being found on the Karmann badge. At some point the body number base changed from xxy95zz to xxy90zz. I require everyone to help with changeover VIN, and body number for each of the changes. Please add paint code and date code from the compliance decal as well. Attached image(s) |
davep |
Mar 18 2022, 06:19 PM
It would appear then that the 914 shared the Karmann line with Beetles, and the Karmann build # could be for either model. What we need to do then is to gather more examples of the Karmann tag numbers, VIN, DOT labels and paint codes and see how they fit. My guess is that they mesh.
Lo-Fi Version | Time is now: 16th May 2024 - 03:13 AM |
