VW Badge location & body numbers, Challenge to determine beginning & end |
davep |
Sep 23 2007, 06:23 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I require help with my research.
Typically, the VW badge was riveted to the right headlight bucket up to the end of 1974 and made its way to the right upper corner of the fuel tank bulkhead in 1975. Also, the body number was originally stamped into the rear trunk floor and made its was to a black riveted tag on the support below the right headlight bucket, as well as being found on the Karmann badge. At some point the body number base changed from xxy95zz to xxy90zz. I require everyone to help with changeover VIN, and body number for each of the changes. Please add paint code and date code from the compliance decal as well. Attached image(s) |
woobn8r |
Oct 2 2007, 10:15 AM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
My '74 VIN# 4742917230 has only two rivet holes in the support by the inner wheel well where the "black plate" once (I assume) resided . There are no stampings I can find in the rear trunk by the tailight.
My compliance sticker (which is Silver, not Black) dates this car as 04/74. The Karman badge shows Chassis # 1659541 and shows L30E as the paint code. The VW plate is also missing however, there are no rivet holes (or evidence of) in either the headlight bucket or the fuel tank bulkhead....and I have looked very carefully. I do have some (poor) pictures I can e-mail you as I am too stupid to know how to post them here.... Hope this helps Sean |
Lo-Fi Version | Time is now: 16th May 2024 - 02:47 PM |
