VW Badge location & body numbers, Challenge to determine beginning & end |
davep |
Sep 23 2007, 06:23 PM
914 Historian Group: Benefactors Posts: 5,143 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I require help with my research.
Typically, the VW badge was riveted to the right headlight bucket up to the end of 1974 and made its way to the right upper corner of the fuel tank bulkhead in 1975. Also, the body number was originally stamped into the rear trunk floor and made its was to a black riveted tag on the support below the right headlight bucket, as well as being found on the Karmann badge. At some point the body number base changed from xxy95zz to xxy90zz. I require everyone to help with changeover VIN, and body number for each of the changes. Please add paint code and date code from the compliance decal as well. Attached image(s) |
davep |
Oct 7 2007, 07:07 PM
Well, Dan (shelby/914) confirms he has the number stamped in the rear trunk. Also, Sean (woobn8r) is pretty confident his should have the tag in the front. So it seems we have it nailed down to midweek 16. So we need to concentrate on that week for the first part of the challenge.
VIN 4742916989 1629515 04/74 last known before use so far VIN 4742917230 1659541 04/74 first known use so far |
Lo-Fi Version | Time is now: 16th May 2024 - 11:05 AM |
