Rocker Panel Question, what to do |
billd |
Sep 24 2007, 12:48 PM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
I've got my front flares riveted on and the rears Cleco-ed in place and have discovered that the FG rocker panels I was planning to install are too short by about 1.5 inches. This is at least in part due to the fact that I aligned the front flares with the front of the front wheel wells - which centered the wheels in the flares. Since the wheel openings in the flares are smaller than the original openings in the fenders, this placed the rear edge of the opening in the flare about an inch ahead of the edge of the original opening. In any case, I'm trying to decide what to do about rockers and am considering the following options:
1. Do nothing - run the car without rockers. After all, they weigh something and don't make the car any faster. 2. (1) but paint the rocker area flat black so no one will notice. 3. Install the FG rockers without mod - misaligned with the flares at the rear by 1.5 inches (or at both ends by .75 inches) - this will look bad. 4. Sell these rockers and get unflared FG rockers (like the steel ones I sold) where the misalignment will be less noticable. 5. Cut the rear ends off the rockers and install the shortened rockers aligned at the front. I'm not sure how this will look. 6. Lengthen the rockers. Cut them in the middle, space the two ends apart 1.5 inches and apply FG cloth and resin to connect the pieces. This will be *a lot* of work. Right now, I'm strongly leaning toward (1) - since I want to spend more time driving and less time fabricating. Anyone have any advice? ----Bill PS. I will note that the Hamilton Racing smurfmobile runs without rockers. PPS. If any of you are installing flares, align them with the rear of the front wheel well and the front of the rear wheel well. |
Lo-Fi Version | Time is now: 28th May 2024 - 04:38 PM |
