A week in Aircooled Heaven, I rebuilding my engine At Jake's |
DNHunt |
Sep 24 2007, 09:48 PM
Yep, what brought me to Atlanta was the opportunity to rebuild my engine in Jake's shop. I shipped it back here about a month ago. We put the details together a few months ago.
I reported at 0600 as I was instructed to do. My stuff had been uncrated and was at a stainless bench. I got a small tour and saw some of the stuff they were working on. Soon enough it was time to get to work. My stuff must have gotten wet in transit because there was surface rust on some of the steel parts. I started in cleaning up. I'm convinced most of engine building is cleaning. Things went well and I met everyone as they came in. Everyone was very friendly and helpful. As you can imagine I had to ask for help quite often. After an hour or so, I started measuring the big ends of the rods. They were pretty good and we determined the clearance was fine. Ok, this isn't so hard. I assembled the crankshaft by lunch. I had the bearings on right, slipped the cam gear on with just a little persuasion. I was starting to feel real good, even a little cocky, joking with the guys and really enjoying it. Jake thought I'd get a shortblock together! After lunch I got the case ready to assemble. I tried in the cam and Brent thought it was really good So, was ready to load the left side of the case. Well, you know what's coming. This was entirely too easy. It started with a few small things. The oil pump showed some wear. Ok, I'll get a new oil pump no biggy. Jake wanted me to match port the inlet for the oil pump so I went and ground it out. Jake looked at it and I left a barb so, I ground and smoothed that. I'd filed abit of the cam gear on the crankshaht to clean it up. I knew wasn't perfect but, I thought it would go. Brent came over to try and turn it and it went for a bit then clunk. What's that?. Brent said cam gear. Utoh! We worked with it a bit but, it wasn't right and it really wasn't getting any better. Brent pressed off the gear and I found an old one to cleanup to replace the one I fuched pulling with a gear puller. An hour later we're ready to put the gear on the crank. I put the hot gear on and Brent says "Is the gear lined up with the key?" I say "Yep" It doesnt slip on and when he persuades it the key starts to come out. Not lined up. Crap When it cooled off he pressed it again. Well, third time was the charm. About then he left and said I could stay if I wanted. I thought I would make sure everything rotated and he said "You could get it to the short block". Message received so I stayed until 9. |
DNHunt |
Sep 24 2007, 09:52 PM
Zimms |
Sep 24 2007, 09:54 PM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
Dave,
Did you buy a 2270 kit when you first upgraded to a 2270 & did you do it in your garage if so? I am planning to go a similar route with a 2270 and MS, but have some rust and body work to do before I even think of allocating funds towards and engine. Thanks, Mark |
John |
Sep 24 2007, 10:14 PM
You were at Jakes?
What the heck is this? I cant believe you had that anywhere near an engine. Attached image(s) |
Jake Raby |
Sep 25 2007, 06:01 AM
Now Dave knows what a 15 hour day is like in Heaven... Tomorrow night I'll pull an all nighter and will see if he can put in a solid 20!!
Dave has been plagued with stupid issues that are absolutely not possibly explained with his engine kit. Dave bought this kit in 2004, before my kit program was refined at the retail level it is now. Because Dave has had the same issues and new issues continued to pop up I invited him to do two things: 1- Send me the engine and I would reassemble and test it for him FREE OF CHARGE. 2- Allow him to come into my world and assemble it under our watchful eyes and dyno it afterward. Dave has been an outstanding, patient and absolutely dedicated customer since day one and I will go out of my way to ensure someone like him who is determined ends up getting as much of my assistance as possible when they have an issue. I have never allowed anyone other than my absolute closest friends to assemble engines here, or even come into the shop and thats because we are very busy and not very social when the clock is ticking. When I met Dave at the end of my cross country trip in 2006 I wanted to help him sort these issues he had been having even more than ever and when he hit his last issue thats when I made the invite for him to bring the engine back home and get the problem taken care of. BTW- Dave dug that adjustable wrenc out of the bottom drawer of my tool box, I keep it around for doing plumbing work at the shop and had it handy because I had to inastall a water pressure regulator on the new dyno last week :-)) |
jimkelly |
Sep 25 2007, 07:42 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
very very cool - best to you all!
jim |
URY914 |
Sep 25 2007, 09:09 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
One day I hope to go to Heaven too. (IMG:style_emoticons/default/biggrin.gif)
Joe Ricard |
Sep 25 2007, 09:18 AM
Jake it looks a lot more crowded in the shop than when I was there 2 years ago. Of course ya'll were doing field day.
Dave Good luck in this engine build and may it be your final iteration of the 2270 for your car. |
So.Cal.914 |
Sep 25 2007, 09:22 AM
You were at Jakes? What the heck is this? I cant believe you had that anywhere near an engine. (IMG:style_emoticons/default/av-943.gif) An old wrench told me once "Any tool is the 'Right' tool...If it works. |
rhodyguy |
Sep 25 2007, 09:28 AM
shop area in my garage will be cleaned and sanitized by the time you get home. check with the boss and block out the first wed you have off. i KNOW your weekends will full of non-914 activities for the next year or so. very cool dave. i'll talk to you when you get home. if you should need a pick up at sea-tac, have betsy call me with the flight details and i'll come get you.
k |
Jake Raby |
Sep 25 2007, 11:16 AM
This is our busiest time of the year here at the shop, so things are cluttered much more than I like. I am doing Pinzgauer engine development in the lab right behind where Dave is working and that is making for even more clutter.
Dave has already learned so many tricks... So far today he has used both an oven and a frezer during cylinder and piston assembly! According to conventional; wisdom his engine should never even run :-) |
ConeDodger |
Sep 25 2007, 11:28 AM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
In part because of the problems Dave had, and the support Jake gave him, I have a Raby 2270 kit in my car. I liked the concept of a dyno tested and road tested combo. I just didn't know about Jake...
The support Dave got and is getting, pretty much made my decision. But, I have to say, if given the opportunity Dave got, have Jake assemble it or do it myself under Jake's watchful eye. I would let Jake do it. Dave is one stubborn dude. He is not going to let that engine beat him. |
Jake Raby |
Sep 25 2007, 12:29 PM
Dave isn't stubborn- he is determined and thats why he is in my shop right now.
I do my best to help anyone that buys from us of course if Dave would have been the type to yell, scream and cuss he would have been on his own for the past 3.5 years without any support (I hate people like that and avoid them at all costs!) Lets not forget the significant outlay of time and support that Charles from LN Engineering has put into this very odd, very unexplained one of a kind situation. Charles has "ate" two sets of cylinders, replating, numerous ring sets and even paid serious bucks in consulting with JE Pistons to figure out this issue. So far Charles is in the project more than I am... Probably about 5K as a good estimate. I gave Dave every opportunity to get our free labor, but he was too dedicated to care. |
toon1 |
Sep 25 2007, 02:11 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
This is our busiest time of the year here at the shop, so things are cluttered much more than I like. I am doing Pinzgauer engine development in the lab right behind where Dave is working and that is making for even more clutter. Dave has already learned so many tricks... So far today he has used both an oven and a frezer during cylinder and piston assembly! According to conventional; wisdom his engine should never even run :-) An oven and a freezer to asseble pistons and cyls.!? do tell... I am not familliar with the probs. Dave had with the motor, what were they? what was found to be wrong and how is it getting fixed? |
So.Cal.914 |
Sep 25 2007, 02:25 PM
This is our busiest time of the year here at the shop, so things are cluttered much more than I like. I am doing Pinzgauer engine development in the lab right behind where Dave is working and that is making for even more clutter. Dave has already learned so many tricks... So far today he has used both an oven and a frezer during cylinder and piston assembly! According to conventional; wisdom his engine should never even run :-) An oven and a freezer to asseble pistons and cyls.!? do tell... I am not familliar with the probs. Dave had with the motor, what were they? what was found to be wrong and how is it getting fixed? You take the nachos out of the oven and the pepperment schnapps out of the freezer. Once consumed, proceed with assembly of cylinder and piston. (IMG:style_emoticons/default/blink.gif) |
jd74914 |
Sep 25 2007, 02:28 PM
This is our busiest time of the year here at the shop, so things are cluttered much more than I like. I am doing Pinzgauer engine development in the lab right behind where Dave is working and that is making for even more clutter. Dave has already learned so many tricks... So far today he has used both an oven and a frezer during cylinder and piston assembly! According to conventional; wisdom his engine should never even run :-) An oven and a freezer to asseble pistons and cyls.!? do tell... I am not familliar with the probs. Dave had with the motor, what were they? what was found to be wrong and how is it getting fixed? An oven expands the cylinders, a freezer shrinks the pistons and the rings go in at room temp? (IMG:style_emoticons/default/laugh.gif) |
brer |
Sep 25 2007, 02:31 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
i'd put my money on either the piston pin,
or the nachos. |
McMark |
Sep 25 2007, 02:37 PM
(IMG:style_emoticons/default/agree.gif) Wrist pin is pretty likely.
KELTY360 |
Sep 25 2007, 02:42 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
So.Cal.914 |
Sep 25 2007, 02:45 PM
Lo-Fi Version | Time is now: 17th May 2024 - 05:15 PM |
