| HAM Inc |
Oct 3 2007, 09:34 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Over the past few months members of 914 World came through for me as I searched for parts for my F-Prod car. Good deals and even some freebies followed my desperate pleas for help. Now I'd like to give back to the community the best way I can, so I'm offering a wiz-bang deal on my value-added cylinder head service to the first 5 914 World members to PM me. I always give a 10% labor discount to members, but for this offer I'm slashing the regular $950.00/pair price to $800.00 (no added 10% discount). This is a turn key job and includes the following new parts parts and service.
-42mm x 36mm stainless valves -Guides -Seats -Manton single springs -Chromoly retainers -Ground keepers -HD rocker studs -HD ex. studs -Meticulous cleaning -2 hours of casting crack/damage repair -2.0 914 plug bosses are welded shut and new plug threads machined. No extra charge for 12mm threads, but must be requested as 14mm is the default. 1.7 and 1.8 threads repaired as needed. -Machined for oversize valve seats with proper interference fit. Seats are hand blended to port bowl. 1.7 and 1.8's upgraded to 42 x 36 valves with bowl work performed to blend seats. -Chambers hand deburred -Rocker vent tubes replaced with welded billet tubes. -Ex. stud bosses are machined for new step studs and oval counterbore is re-faced. No shortcuts taken here (or anywhere for that matter) If prior work has been done or bosses are damaged, they are removed and new ones welded in. Machine work is done on a Bridgeport mill using a fixture to ensure original factory fit. -Damaged M5 and M6 threads repaired as needed -Valve seats receive a radius cut using Serdi tooling -Flycut and depth correction cut -Valve stem ht's set to within .25mm, which is a 1/4 turn of an adjuster. -All studs installed -Chambers cc'd -Assembled, bagged, boxed and shipped (shipping not included) This is a true turn-key service that allows the customer to remove the heads from the box, inspect and install. Options are available with this service like valve size upgrades, dual springs, extra port work, etc. Heads must be in servicable condition and be free of hack work from previous shops, excessive damage from detonation or dropped seats or valves. Dropped seats that just turned sideways and stuck will be accepted. A 50% deposit will be required when the heads are shipped and a committment to pay the balance within 2 weeks of notification that the head are ready. I hope this helps some members keep their teeners running without breaking the bank. Cylinderhead work isn't cheap for these engines, so maybe this will come as a welcome oppurtunity for some folks. I would prefer that members interested in this offer PM me for details and to make arrangements. Thanks! Len Hoffman |
| ConeDodger |
Oct 3 2007, 09:49 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,299 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Len this is a great deal! I have one head off and the other has a stubborn cheesehead on the undertin. I have a new tiny vise grip sitting next to me. (IMG:style_emoticons/default/biggrin.gif) This motor is for Nicho who is 10 years old so we are not in a hurry (IMG:style_emoticons/default/smile.gif)
I will get them out to you when I get them off and packed... |
| McMark |
Oct 3 2007, 11:16 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
very cool of you Len. This is a great opportunity for 5 members.
| Borderline |
Oct 3 2007, 11:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
That's a great deal! I know it sounds like a lot of money, but he is doing a lot of work ! I am very happy with the work Len did on my heads last year.
Thanks Len! |
| HAM Inc |
Oct 3 2007, 12:12 PM
Thanks for the kind words Bill. Glad you're happy with your heads. I aim to please!
| 914Sixer |
Oct 3 2007, 01:38 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,387 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Len does excellent work. I will post some pictures of the heads he did for me later.
| azbill |
Oct 3 2007, 03:36 PM
Member ![]() ![]() Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
I also have a set of Len heads. The workmanship is excellent. and the heads produce Horsepower and torque. Between Len and Jake help I have a running car that puts you back into the seat (dyno at 140 Hp with 165 Ft/Lb.) I'm very happy.
Bill Shaffer |
| HAM Inc |
Oct 3 2007, 04:03 PM
Thanks guys! I enjoy this work. The best part is hearing that my customers are happy with their engines performance and ripping up asphalt!
| jaminM3 |
Oct 3 2007, 04:10 PM
Member ![]() ![]() Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
PM sent, do you have 5 yet? (IMG:style_emoticons/default/piratenanner.gif)
| HAM Inc |
Oct 3 2007, 06:32 PM
I have 2 slots left now.
| crash914 |
Oct 3 2007, 07:12 PM
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Go for it!
Great deal and reflects a lot of work. Len, got my old heads ready yet? |
| Project 6 |
Oct 3 2007, 08:16 PM
large member ![]() ![]() Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
How long has your shop been around?
| HAM Inc |
Oct 4 2007, 07:54 AM
I opened in '96.
| Lavanaut |
Oct 4 2007, 11:33 AM
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Hi Len,
For the uninitiated, can you talk a little bit about what the benefits of having this service done would be? I have a stock '74 that runs great as-is. Could I expect a noticeable difference after having this work done? Thanks for your time. |
| HAM Inc |
Oct 4 2007, 12:15 PM
Lavanut if your engine runs great now you won't see a very big improvement in performance unless you make other changes too. If it's running great and you don't want to make a cam change, I'd keep on driving it until it gives some indication it's time to do some work.
The one consideration you have to keep in mind is that from time to time even good running T4 engines toss a valve seat. Peace of mind would be the biggest benefit to pulling your heads from a good running engine and having this service done. You can help prevent this by installing a CHT guage and monitoring your CHT's. This might spark a CHT guage debate. If you are going to monitor just one cylinder, monitor #3. Westach makes a single guage that allows all four cylinders to be connected to one guage. I have driven a race car that had this and really liked it. Over the years I have had lots of 1.8 and 2.0 914 heads come to me with an intake seat dropped and wedged sideways in the chamber of a head that showed no obvious signs of overheating. My hunch is that the seat fatiqued and the engine had a spike in temp. I have had seats fall out in my oven from just gravity when heated to 400*. I then measured the interference fit and every one I hve checked has been between .003" and .004", not enough. I have a hard time believing that VW installed the seats so loose. That is why I think the seats fatique over time and lose the ability to expand and contract with the head, eventually becoming static when exposed to heat. As I said before, if it's running good and you aren't interested in making other upgrades I'd keep on motoring. Just keep an eye on your vitals! |
| JeffBowlsby |
Oct 4 2007, 02:17 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,160 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I would be interested in this Len, if you can wait a few months. Is there a time window for this offer?
| HAM Inc |
Oct 4 2007, 04:40 PM
Jeff the offer was supposed to be good for a week from the post time yesterday. But since I forgot to put that in the post, I'll accept heads shipped by next Thursday. Still have 2 slots open.
| solex |
Oct 4 2007, 09:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Len,
Does my order count? Thanks, Dan |
| Lavanaut |
Oct 5 2007, 11:18 AM
Lavanut if your engine runs great now you won't see a very big improvement in performance unless you make other changes too. If it's running great and you don't want to make a cam change, I'd keep on driving it until it gives some indication it's time to do some work. Thanks Len, very useful information. For now, I'll keep driving mine until its time comes. (IMG:style_emoticons/default/driving.gif) |
| HAM Inc |
Oct 7 2007, 10:18 AM
We now have just 1 slot left and the deadline for shipping is Thursday the 11th. For the folks who have committed to this offer please make sure you meet this deadline as we are doing these heads in a batch run to economize time and maximize your savings.
Thanks! Len |
Lo-Fi Version | Time is now: 12th January 2026 - 11:29 PM |
