Mallory Install Part 3--No spark |
jaybird840 |
Oct 9 2007, 10:08 AM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
OK,
On to phase three of the Unilite install. I got the dizzy drive properly indexed and the dizzy set at TDC on #1. I verified by thumb-over-hole and by watching the valves. Now I am getting no spark out of the dizzy. Car ran on 009 dizzy two days ago. Replaced coil with new Bosch blue and installed the Unilite. I have checked and replaced all of the spade terminal ends, so I should have good contacts. From the Unilite, I have the brown wire to engine block ground, the green wire to coil neg (I assume that's the one with the minus sign), and red wire to coil positive (the one marked "15"). I say no spark, because I am getting no flash from a timing light (which worked two days ago, and shows to have power--it's digital). Attached is a pic of the coil. Let me know where to go from here.... |
Lo-Fi Version | Time is now: 19th May 2024 - 02:19 AM |
