> The Cost of "DIY" Media Blasting..., or Should I buy the equipment for only one car project...
73Phoenix20
post Oct 9 2007, 11:35 AM
I know some of you folks will have some advise for me on this subject...
I need answers to several questions regarding media blasting...
1. Is the 'Pressure Pot" Blast System significantly superior to the gravity fed system?
I can get either one at Harbor Freight (and prolly other places) for about $50.00 difference, which is trivial, IF the Pressure Pot system really works better...
2. I can get Aluminum Oxide media for $40 per 25lb box... how much surface area will this cover, assuming I am removing the factory paint down to bare sheetmetal? 5 square feet? 10 square feet? More? For an easy example, will 25 lbs strip the hood of a 914? Or maybe the hood and trunk (top surface only)?
3. I can get crushed walnut shells for about $20.00 per box, but i assume they are much less effective? How much less? Will it take twice as much in walnut shells vs. aluminum oxide?
4. Luckily, I only need to strip the exterior, as the interior is in fantastic shape, and I am repainting to original color. What is the best material to use to mask areas that I don't want to get "accidentally" blasted? Heavy duct tape? Multiple layers of heavy plastic sheeting?
5. Will Aluminum Oxide risk warping of the sheet metal due to heating? I understand walnut shells won't warp panels? True or not? If they are only marginally less effective, and half the price, I guess I will go with the walnut shells?
Prolly more, but that is all I can think of right now! Thanks folks!
73Phoenix20   The Cost of "DIY" Media Blasting...   Oct 9 2007, 11:35 AM
Travis Neff   Aluminum oxide is VERY aggressive, get ready for a...   Oct 9 2007, 11:45 AM
rhodyguy   if you don't have one, the biggest exspence wi...   Oct 9 2007, 12:11 PM
Brian Mifsud   When you are ready to media blast, rent a monster ...   Oct 9 2007, 01:11 PM
73Phoenix20   I'm running a 1.5 HP Compressor on a 250 Gallo...   Oct 9 2007, 01:19 PM
Vacca Rabite   If you trap the media, you can generally run it th...   Oct 9 2007, 01:24 PM
rhodyguy   that compressor rental is a good idea. you know yo...   Oct 9 2007, 01:31 PM
Brian Mifsud   Baking soda is a "salt", so you should b...   Oct 9 2007, 01:33 PM
73Phoenix20   Hmmm... I like the BIG Rental Compressor idea, and...   Oct 9 2007, 01:45 PM
rhodyguy   with the huge volume you can move up to a presure ...   Oct 9 2007, 01:53 PM
Richard Casto   I am going through this right now. I had initially...   Oct 9 2007, 04:23 PM
Wilhelm   I have generally had better success with pressure ...   Oct 9 2007, 05:20 PM
73Phoenix20   Hey, all great info! I will definitely want t...   Oct 9 2007, 06:30 PM
majkos   :popcorn: Yeah! Keep them coming! :headban...   Oct 9 2007, 06:42 PM
scotty b   FYI soda blasting requires a completely different ...   Oct 9 2007, 07:13 PM
73Phoenix20   I'm thinking of getting one or two of those di...   Oct 9 2007, 08:46 PM
Jeff Hail   Easy home blasting method: If you have one of thos...   Oct 9 2007, 10:03 PM
73Phoenix20   A Canopy! Great idea! I bought one a cou...   Oct 10 2007, 08:23 AM
Krieger914   We used to blast the airframes of B-25's with ...   Oct 10 2007, 10:05 AM
- Lo-Fi Version Time is now: 16th March 2026 - 02:46 PM
