| Lavanaut |
Oct 11 2007, 04:31 PM
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Something's not right. Smells like exhuast in the cabin, and a very slight backfire has developed on the left side...like a very subtle 'pop pop pop' at idle, and a more pronounced, single 'POP' on decel around 2800-3100 RPM. I've got it paired up to a Triad exhaust. What gives?
I swore to my wife that I wouldn't have the car up on ramps for a while since I just pulled it down (after 2.5 months) 2 days ago, so I took it to a custom exhaust place here in town and had them do the install. They said I needed new hoses (parts 21 & 23 here, hope you don't mind George!). The original ones were put back on, but they're pretty deteriorated and have small holes/cuts in them. Could that be it? I wish I understood how heat exchangers worked. I did a search on google hoping to learn just that but came up empty. Yes, I realize that if there's exhaust pouring into the cabin it could potentially be fatal. I drove the car home with the windows down. (IMG:style_emoticons/default/smile.gif) I intend to contact the shop today, but was hoping to get some feedback from you all first. Thanks in advance Reid |
Lavanaut Got my SSIs installed Oct 11 2007, 04:31 PM
Rand :( Smelling fumes in the cabin and backfiring/popp... Oct 11 2007, 04:36 PM
Headrage Sounds like an exhaust leak where the h/e's me... Oct 11 2007, 04:53 PM
Brando I agree with the following... MUST be done! A ... May 30 2008, 01:33 PM
McMark SSIs are a PAIN IN THE ASS to fit. Every set I... Oct 11 2007, 05:00 PM
Root_Werks
SSIs are a PAIN IN THE ASS to fit. Every set I... May 27 2008, 06:20 PM
jaminM3 Did the shop even replace the copper gaskets? I al... Oct 11 2007, 05:20 PM
Hammy
Did the shop even replace the copper gaskets? I a... Oct 11 2007, 10:24 PM
orange914
Did the shop even replace the copper gaskets? I a... Jun 4 2008, 07:20 PM
2-OH! Is it exhaust or residual oil burning off the Heat... Oct 11 2007, 05:54 PM
rhodyguy old oil in the heat chambers stinks to high heaven... Oct 12 2007, 08:22 AM
Spoke
old oil in the heat chambers stinks to high heave... Oct 12 2007, 03:18 PM
Lavanaut Wow great feedback. As far as I know they did rep... Oct 12 2007, 03:46 PM
Lavanaut Another. First time I've had my car on a lift... Oct 12 2007, 03:46 PM
Lavanaut Last one Oct 12 2007, 03:47 PM
cassidy_bolger All I can say is, let me know if you drive over to... Oct 12 2007, 06:03 PM
Tom Noticed that your muffler bracket is different tha... Oct 12 2007, 06:44 PM
swl Warning - possible bad info. Gearheads please fla... Oct 12 2007, 07:03 PM
Rand
Warning - possible bad info. Gearheads please fl... Oct 12 2007, 07:31 PM
So.Cal.914
Warning - possible bad info. Gearheads please f... May 30 2008, 02:46 PM
swl My sample space is precisely 1 - that's why I ... Oct 12 2007, 07:37 PM
Andyrew Steve you do have a good idea, but I dont think yo... Oct 13 2007, 06:48 PM
r_towle I use my shoe.
Start the car, sit down behind.
Pu... Oct 13 2007, 08:53 PM
swl Lol - with that triad exhaust the shoe trick would... Oct 14 2007, 07:27 AM
Lavanaut Update ~ the shop was willing to refit the HEs for... May 27 2008, 02:44 PM
What I'm being told now is that the driver... May 27 2008, 02:57 PM
Bartlett 914
Update ~ the shop was willing to refit the HEs fo... May 27 2008, 03:31 PM
Phoenix 914-6GT If it's not too much you may as well have it f... May 27 2008, 02:56 PM
Phoenix 914-6GT I would think you could find out rather easily for... May 27 2008, 03:00 PM
914-8 I had a similar problem when I had my 2.0.
I know... May 27 2008, 03:00 PM
Lavanaut
[quote name='Lavanaut' post='1037324' date='May 2... May 27 2008, 03:32 PM
Phoenix 914-6GT Not really... Take a piece oftin and block off one... May 27 2008, 03:37 PM
Garold Shaffer It could very well be the pipe inside the tin has ... May 27 2008, 04:55 PM
rhodyguy what did they do to pinpoint the leak in the pipin... May 27 2008, 10:32 PM
Lavanaut
I doubt the pipe is leaking inside the tin but ma... May 30 2008, 01:04 PM
Bartlett 914
I doubt the pipe is leaking inside the tin but m... May 30 2008, 03:34 PM
Marty Yeoman
Time to put the stock exchangers back on I guess ... May 30 2008, 02:06 PM
Lavanaut
I don't think there's much of a market fo... Jun 4 2008, 12:19 PM
Garold Shaffer
I don't think there's much of a market f... Jun 4 2008, 01:28 PM
Lavanaut I must not have been clear. With the HE off of th... May 30 2008, 02:50 PM
Gint
I must not have been clear. With the HE off of t... May 30 2008, 04:21 PM
Headrage :agree: just fix the leak.
It wont take much to ... May 30 2008, 03:04 PM
Marty Yeoman
After further consideration though, I'm going... May 30 2008, 03:17 PM
Lavanaut Yep, bummer. They look fine, just one very small ... May 30 2008, 03:39 PM
Bartlett 914
Yep, bummer. They look fine, just one very small... May 30 2008, 05:06 PM
Marty Yeoman
Inside the tins the pipes are not bent much.
I... May 30 2008, 05:44 PM
Bartlett 914
... May 30 2008, 07:07 PM
kwales That's just odd.
I do remember in metallurgy ... May 30 2008, 07:42 PM
Marty Yeoman
Are those your pipes in the picture? Why were the... May 30 2008, 11:16 PM
Lavanaut Went and picked up the car today. Check out the p... Jun 5 2008, 01:50 PM
This was obviously not a split at the seam formed... Jun 5 2008, 02:19 PM
orange914
This was obviously not a split at the seam forme... Jun 9 2008, 12:13 AM
TeenerTim That's a huge amount rust for a stainless pipe... Jun 5 2008, 02:54 PM
6freak
That's a huge amount rust for a stainless pip... Jun 5 2008, 03:34 PM
That's a huge amount rust for a stainless pip... Jun 10 2008, 01:23 PM
Lavanaut One more, just for kicks. :wub:
Jun 5 2008, 01:51 PM
ericread OK, You've roped us all in...
Time to post ei... Jun 5 2008, 02:01 PM
Lavanaut You forgot a smiley at the end of your first sente... Jun 5 2008, 02:09 PM
ericread
You forgot a smiley at the end of your first sent... Jun 5 2008, 02:12 PM
Marty Yeoman Nice hole!!
I knew Shayne would take good... Jun 5 2008, 02:27 PM
Lavanaut
In just one of the pipes though? It seems like i... Jun 5 2008, 02:32 PM
6freak
In just one of the pipes though? It seems like ... Jun 5 2008, 02:47 PM
Garold Shaffer I wish I had the pictures from Brad's shop. ... Jun 5 2008, 02:43 PM
Garold Shaffer
I wish I had the pictures from Brad's shop. ... Jun 8 2008, 10:15 PM
Lavanaut Torque is a measure of rotational force around a p... Jun 5 2008, 02:54 PM
Gint Yikes!
I've been wondering if mine leak... Jun 8 2008, 11:34 PM
Brando Holy... wow... I've never seen SSI's like ... Jun 9 2008, 11:33 AM
Headrage Take a magnet to the section of pipe that was cut ... Jun 9 2008, 04:10 PM
Lavanaut Does not. :wavebye: Jun 9 2008, 04:14 PM
Eric_Shea
That car would look sweet with 5-lug Fuchs! ... Jun 9 2008, 05:27 PM
kwales A neighbor of mine looked at my new SSI's and... Jun 9 2008, 07:40 PM
Garold Shaffer
A neighbor of mine looked at my new SSI's an... Jun 9 2008, 09:51 PM
6freak
A neighbor of mine looked at my new SSI's a... Jun 9 2008, 10:33 PM
orange914
LOL just suck on the tail pipe :rotfl: once again... Jun 10 2008, 12:43 AM
Lavanaut ...that's exactly how the shop determine mine ... Jun 9 2008, 10:19 PM
9146986 If your SSI's have cracks anything like that T... Jun 10 2008, 09:58 AM
ericread
If your SSI's have cracks anything like that ... Jun 10 2008, 10:50 AM
9146986 There is a product for small aircraft, most of whi... Jun 10 2008, 12:48 PM
9146986 FWIW the factory used a form of stainless tubing w... Jun 10 2008, 08:52 PM
Racer Chris
FWIW the factory used a form of stainless tubing ... Jun 11 2008, 08:50 AM
9146986
The oem tubing was also much heavier wall thickne... Jun 11 2008, 12:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:20 AM |
