better? 915 or boxster (5sp) transmission in 914 |
Wes V |
Oct 15 2007, 12:02 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
In light of the fact that it is possible to use either transmission in a 914, it poses a couple questions.
Which transmission is stronger, 915 or boxster 5 speed? Which has the best support for repair? Which has the best selection of aftermarket gears? After going through the expense of doing the Wevo conversion on the 915, would it shift as well as the boxster with cable shifter. Am I correct that the total cost of converting a 915 using the Wevo kit would come to close to $2500 minimum. ($2000 for sideshift kit and another $500 for shifter) This assumes you do the work your self. It seems like the 915 would cost twice the amount (for all hard parts and used transmission) that a boxster would cost. Wes |
Chuck |
Oct 16 2007, 09:52 AM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
(IMG:style_emoticons/default/welcome.png) The 915 is going to be cheaper to do. As I understand, the Boxter transmission requires a fair amount of work to get it to fit into the 914. One member here (abc123 I believe it is) did a Boxter transmission. There is a writeup here as well as on the Pelican Parts board. He hired it out and I believe the total cost was close to $20k. The 915 has been done many many times and there is a lot of help out there for getting it in.
The Boxter tranny is easier to shift. It is also stronger. Depending on what you're doing, the 901 may be your best choice. Replace the shifter bushings and put in a Rennshifter and you should notice marked improvement. I plan to run my 901 with a Rennshifter behind my 3.2. I'm sure others with more knowledge than me will chime in on some of your other questions. |
Aaron Cox |
Oct 16 2007, 10:37 AM
i believe andys stuffed an audi or boxster tranny in his 914. cool little sub frame.
there is a pic of it in the 'paddock section' in a thread called 'springs and perches' |
andys |
Oct 16 2007, 01:15 PM
I'm not sure how one would go about adapting the Boxster/Audi 012 transaxle to a type IV motor. The starter mounting provision is not in the traditional 914 location. You'd also need an adapter plate, as the bellhousing is not the standard Porsche circular type design. The 6 speed Boxster transaxle, though circular bellhousing design, has the starter in the 12 o'clock position.
Andys |
Brett W |
Oct 16 2007, 11:55 PM
You can not use a Boxster transmission in a 914 with either and aircooled 6 or a four cylinder. There is no provision for starter.
jd74914 |
Oct 17 2007, 12:07 AM
Its been done Brett . . . how I don't quite know. This scar has a Boxster 6spd and 3.2L /6. I wish there were more pictures to figure out how.
andys |
Oct 17 2007, 11:33 AM
i believe andys stuffed an audi or boxster tranny in his 914. cool little sub frame. there is a pic of it in the 'paddock section' in a thread called 'springs and perches' Here's a slightly better photo of the install. Transaxle is an 01E 6 speed. This is however a V8 conversion. Doesn't the 6 speed Boxster locate the starter on the engine block at 12 o'clock and points forward? No starter mounting provision on the trans, right? Andys Attached thumbnail(s) |
Brett W |
Oct 17 2007, 11:56 PM
Not sure about the 6 speed but my five speed would not work behind any four or 6 without an adapter plate and some sort of starter setup.
Brett W |
Oct 18 2007, 12:07 AM
Here is another pic.
Notice the cutout for the nose of the starter. Attached thumbnail(s) |
PRS914-6 |
Oct 18 2007, 12:15 AM
The 915 gives some nice options...I bought a used one for $500.00 and rebuilt it.
Gears are readily available in almost any configuration WEVO kit makes a nice installation and works great No cable shifter required Bolt in deal, no fab required No need to buy a $500.00 shifter. WEVO, good shift linkage (Patrick) and 911 sport mounts will give the desired results. A stock 915 shifter can be had for about $50.00 if you look I have a re-geared 915 in my car with the above. It shifts like butter and I'm quite happy with it. First gear is good for 52 mph. |
jimkelly |
Oct 18 2007, 07:53 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
doesn't 915 require RP to be flipped? at what cost and who does it?
my understanding is that the 930 box is the best of the bunch? but a 901 box can handle 300hp and long as you don't have fat grippy rubber. patrick motorsports for linkage - http://www.patrickmotorsports.com/category/10/ fun 901 box video - http://www.renegadehybrids.com/914/Subie/Videos/Video01.avi jim The 915 gives some nice options...I bought a used one for $500.00 and rebuilt it. Gears are readily available in almost any configuration WEVO kit makes a nice installation and works great No cable shifter required Bolt in deal, no fab required No need to buy a $500.00 shifter. WEVO, good shift linkage (Patrick) and 911 sport mounts will give the desired results. A stock 915 shifter can be had for about $50.00 if you look I have a re-geared 915 in my car with the above. It shifts like butter and I'm quite happy with it. First gear is good for 52 mph. |
Brett W |
Oct 18 2007, 09:39 AM
Yes the 915 Requires the ring or the tranny to be flipped.
Aaron Cox |
Oct 18 2007, 10:47 AM
as do any rear engine trannies that are going into a mid engine config
g50 - upside down 930 - flip or run upside down 915 flip or run upside down |
andys |
Oct 18 2007, 10:58 AM
Here is another pic. Notice the cutout for the nose of the starter. Brett, I've never actually seen a Boxster 5 speed engine and trans assembled together. Does the starter fit the pocket of the trans, or is it located elsewhere? In that pocket location, would the strater not run into the right cylinder bank? I don't quite see how it would fit. Got a photo of the assembly? BTW, that model of transaxle is the same as the Audi 012 5 speed found in nearly every Audi/Passat front drive car from somewhere around '97 and up. You don't need to pay Porshe prices. I've seen low mileage 012's for $300. The only thing you get with the Boxster version (if it's included in the sale), is the shift linkage for the two push-pull cables. Andys |
roadster fan |
Oct 18 2007, 12:09 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
I have a Boxster 6-speed, and the starter pocket is at the 12-o-clock position. I really cant comment on what would be required to make that fit with a aircooled 4 or 6.
The issue with the Boxster 6 speed mated to non-aircooled motors looks to be how tall it is and modifications are required to the trunk to make it fit. The rear trunk support (dog-bone shaped support) needs to be notched. I think the pelican thread on the subject had some good pics, IIRC. Jim |
Brett W |
Oct 18 2007, 06:54 PM
Actually my gearbox is from a 99 Passat. According to the Getrag website it is the same as the Boxster tranny. But I know for a fact the output shaft flanges are different, but they are interchangeable. I thought the starter came out at the twelve o'clock position but didn't see it in the pic of a Boxster engine.
The tranny featured in the Pelican article is a different tranny. It is a G50 variant. |
Dr Evil |
Oct 18 2007, 09:40 PM
What are you going to put it on? V8, /6, /4?
Brett W |
Oct 19 2007, 01:31 AM
Me?
EMRoadster |
Oct 19 2007, 02:09 AM
Autocrosser Group: Members Posts: 65 Joined: 20-August 05 From: Tucson, AZ Member No.: 4,620 |
as do any rear engine trannies that are going into a mid engine config g50 - upside down 930 - flip or run upside down 915 flip or run upside down Anyone have any good souces for info/tips/specifics etc. on what should or should not be done when running a 915 upside down? Thanks, |
LvSteveH |
Oct 19 2007, 02:20 AM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
The 915 is fairly simple to flip the ring and pinion internally, so it's uncommon to see them run inverted.
The 930 requires quite a bit of work to flip the ring and pinion, so you'll see several cars running them inverted instead. The G50 diff is not able to be flipped, so they all run inverted in a mid-engine configuration, but do so without complaint. as do any rear engine trannies that are going into a mid engine config g50 - upside down 930 - flip or run upside down 915 flip or run upside down Anyone have any good souces for info/tips/specifics etc. on what should or should not be done when running a 915 upside down? Thanks, |
Lo-Fi Version | Time is now: 17th May 2024 - 09:15 PM |
