Replacing old, original, cracked dash top (pad) |
1970 Neun vierzehn |
Nov 8 2007, 11:03 AM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
I'm certain that there are numerous, satisfied recepients of Camp914s' dash top refurbishments, but, has anyone in the concours circles had firsthand experience with this repair. The photos on their site indicate that their refinishing can't be told from new. If this is the case, I'll be buying one. However, I don't want to get a renewed dash pad if it's apparent that it doesn't match the original.
Paul |
JeffBowlsby |
Nov 8 2007, 03:52 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its been a few years since I saw craigs first couple of dash redos so take it for what its worth, hopefully Craig will chime in and post close-up photos of the finish.
What I remember was that the finish was very very nice, but it was not the identical grain as stock. Remember also, there was more than one stock grain. Its a very good product, and close, but not identical. To be the most convincing, one might consider refinishing all the interior pads...upper/lower dash, and the 3 Targa bar pieces to match. |
Pat Garvey |
Nov 8 2007, 11:06 PM
I'm certain that there are numerous, satisfied recepients of Camp914s' dash top refurbishments, but, has anyone in the concours circles had firsthand experience with this repair. The photos on their site indicate that their refinishing can't be told from new. If this is the case, I'll be buying one. However, I don't want to get a renewed dash pad if it's apparent that it doesn't match the original. Paul Have you tried looking for a factory replacement through the usual channels - here, eBay, Craigslist? They do come up from time to time. This isn't a horrible change to make, IF you're 30, but it does require a lot of contortion & cussing. Can your old 6'5" frame still contort? (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/poke.gif) Pat |
sixerdon |
Nov 10 2007, 12:29 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
Be careful. There is an early and late style pad. '70 & '71 are early. When the '72's came out, the glove box door got shorter due to the added vent and the pad cutout in the right corner near door compensted for it. Not everybody knows this.
What happens is that the door on the early dash will not fully open with a late pad. It will work, but it's not a great fit. I found this out when I replaced my '70 pad with a nice '76 pad 10 years ago. Don |
Lavanaut |
Jul 25 2008, 01:10 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
Lots of great info here as usual. Can anyone tell from these pics whether this is an early or late /6 dash? Apparently it has the "loose" (vs. "tight", seller's words I swear) grain.
(IMG:style_emoticons/default/confused24.gif) |
sixerdon |
Jul 25 2008, 07:19 PM
No, I can't tell by the pictures. The key is the width of the glove box recess in the top. The '70 & '71 (4 & 6) cars has a wider glove box door. The recess got wider in '72 with the addition of side vents making the glove box door narrower. Get a dimension of the width of the notch and compare it with your own car.
Don |
sixerdon |
Jul 25 2008, 07:23 PM
No, I can't tell by the pictures. The key is the width of the glove box recess in the top. The '70 & '71 (4 & 6) cars has a wider glove box door. The recess got wider in '72 with the addition of side vents making the glove box door narrower. Get a dimension of the width of the notch and compare it with your own car. Don I should have said "the recess got narrower in '72 with the addition of side vents". D |
Jul 25 2008, 07:36 PM
sixerdon |
Jul 25 2008, 08:01 PM
Paul, Did you have yours recovered by Camp 914? Don |
McMark |
Jul 28 2008, 03:42 AM
I just installed a Camp914 pad. I'll take pictures on Tuesday. If you didn't see two next to each other you would never know the difference. As far as I'm concerned it's a 'no-compromises' replacement. Anyone who claims they can tell a difference needs to prove it, because I'm a skeptic.
Lavanaut |
Jul 29 2008, 11:44 AM
QUOTE Here is a close up of a 1970 dash top "grain pattern". Great pic Paul, thanks very much. QUOTE I just installed a Camp914 pad. I'll take pictures on Tuesday. If you didn't see two next to each other you would never know the difference. As far as I'm concerned it's a 'no-compromises' replacement. Anyone who claims they can tell a difference needs to prove it, because I'm a skeptic. Very interesting, I look forward to seeing those pics Mark! |
McMark |
Jul 29 2008, 01:08 PM
Here they are. Again, the grain may look slightly different in a side-by-side, but even in two cars next to each other I think anyone would be hard pressed to know without guessing.
Attached thumbnail(s) |
Leo Imperial |
Jul 29 2008, 07:45 PM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
Just pulled this out of a 71' looks pretty close to me, except the original is not as clean as the nice new version Mark has. The shock this one has no cracks or sagging over the guages. I say shock because the rest of the car is a mess.
I was thinking about using it on my car, but this thread has me wondering what this one is worth (IMG:style_emoticons/default/idea.gif) Attached image(s) |
Lavanaut |
Jul 31 2008, 04:21 PM
No, I can't tell by the pictures. The key is the width of the glove box recess in the top. The '70 & '71 (4 & 6) cars has a wider glove box door. The recess got wider in '72 with the addition of side vents making the glove box door narrower. Get a dimension of the width of the notch and compare it with your own car. Don I just went out to measure the opening in my own car and found something very interesting. Depending on what you guys think, "interesting" may be the wrong word. Anyway, take a look at the pic below. Based on what you're saying Don, it appears to me that my car has the wrong dash in it as it sits...? (IMG:style_emoticons/default/confused24.gif) The glove box door doesn't open fully, but I hadn't noticed it until now. (IMG:style_emoticons/default/WTF.gif) (sorry...crappy cell pic) |
Jul 31 2008, 08:32 PM
No, I can't tell by the pictures. The key is the width of the glove box recess in the top. The '70 & '71 (4 & 6) cars has a wider glove box door. The recess got wider in '72 with the addition of side vents making the glove box door narrower. Get a dimension of the width of the notch and compare it with your own car. Don I just went out to measure the opening in my own car and found something very interesting. Depending on what you guys think, "interesting" may be the wrong word. Anyway, take a look at the pic below. Based on what you're saying Don, it appears to me that my car has the wrong dash in it as it sits...? (IMG:style_emoticons/default/confused24.gif) The glove box door doesn't open fully, but I hadn't noticed it until now. (IMG:style_emoticons/default/WTF.gif) (sorry...crappy cell pic) You are correct, wrong dash top. Here's a photo showing correct fitment, though the install isn't complete. This is for a 1970. Paul Attached image(s) |
Lavanaut |
Jul 31 2008, 08:36 PM
You are correct, wrong dash top. Here's a photo showing correct fitment, though the install isn't complete. This is for a 1970. Paul Thanks for the pic Paul. Yeah, the more I looked at my pic the more obvious it was that it's the wrong dash top. I guess I'm in the market for an early one. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/hijacked.gif) ...sorry about that. This post has been edited by Lavanaut: Jul 31 2008, 08:37 PM |
Jul 31 2008, 08:42 PM
You are correct, wrong dash top. Here's a photo showing correct fitment, though the install isn't complete. This is for a 1970. Paul Thanks for the pic Paul. Yeah, the more I looked at my pic the more obvious it was that it's the wrong dash top. I guess I'm in the market for an early one. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/hijacked.gif) ...sorry about that. As sixer(Don) mentioned, when the 914 dash included the side, fresh air vents starting in 1972, the opening for the glove box door became marginally narrower. Paul |
Jul 31 2008, 08:45 PM
Paul, Did you have yours recovered by Camp 914? Don Don, I'm sorry I overlooked your question. Yes, Camp 914 is restoring my dash top. Paul |
sixerdon |
Aug 1 2008, 08:03 PM
Yes Lavanaut, that's exactly what I'm talkin' about. The glove box will open, but not with the "pop". Eventually what can happen is that the g-box door will chafe the recess of that expensive top. If you have an uncracked top, maybe you can trade with someone with an early one in the same condition. It would seem the early ones would be more rare than the later ones.
Good pictures of the detail by you and Paul for future reference. Paul |
sixerdon |
Aug 4 2008, 09:43 PM
Lots of great info here as usual. Can anyone tell from these pics whether this is an early or late /6 dash? Apparently it has the "loose" (vs. "tight", seller's words I swear) grain. (IMG:style_emoticons/default/confused24.gif) In case no one noticed, this particular top sold on ebay for over $700. Go figure. Don |
Lo-Fi Version | Time is now: 6th May 2024 - 02:22 PM |
