high-torque starters, good or bad? |
SLITS |
Nov 13 2007, 07:56 AM
The only time I lost teeth on a /6 flywheel was with an OEM Bosch starter (SR68X or Lester 16246).
Rimco repaired the flywheel for $105.00 (new ring gear & surface grind). And as stated above, "it is the quality of the rebuilder". Most local small shops will do a better job, but cost more than a production rebuilder. Don't sell the jap starters short .... they are better engineered than Bosch ever thought of. |
jasons |
Nov 13 2007, 09:08 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I have the IMI starter and it works great. Install was a little tricky, because the positive battery lug was on top of the starter. So its in between the trunk floor and the starter. But I have none of the above mentioned problems.
FWIW, high torque starters are just Toyota starter motors adapted to other cars. So as far as reliability, the starter should be more reliable than your car. However, the starter may only be as good as the company that adapted the toyota starter motor to your application. Thats why some people may be experiencing problems. |
SLITS |
Nov 13 2007, 11:23 AM
Actually two manufacturers ... Nippondenso and Hitachi
PRS914-6 |
Nov 13 2007, 11:51 AM
I have the IMI starter and it works great. Install was a little tricky, because the positive battery lug was on top of the starter. So its in between the trunk floor and the starter. But I have none of the above mentioned problems. My connection was on the bottom. (Highperformance USA) |
Dr Evil |
Nov 13 2007, 12:31 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have the one Paul has and it was the one that was NOT goofing up teeth. The other one I am not sure about.
jasons |
Nov 13 2007, 12:38 PM
I have the IMI starter and it works great. Install was a little tricky, because the positive battery lug was on top of the starter. So its in between the trunk floor and the starter. But I have none of the above mentioned problems. My connection was on the bottom. (Highperformance USA) I wonder if I put mine in backwards? (IMG:style_emoticons/default/idea.gif) IIRC, it seemed like it would mount either way, but the upwards way made more sense somehow. Maybe the +cable didn't like the run? I may have to revisit that. |
BKLA |
Nov 13 2007, 02:21 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
I haven't had a single problem since replacing the flywheel and installing a new bosch starter. Maybe the Hi torque was a bad install, but the new setup sounds sooo much quieter and starts so much quicker.
I am a happy camper now! (IMG:style_emoticons/default/biggrin.gif) If you use the Hi Torque, a shim is what I'd recommend - not washers. |
Air_Cooled_Nut |
Nov 13 2007, 04:07 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
http://www.icbm.org/cmgallery/index.php?cat=13
Click on the "HPA Starter" album. I need to update the album to show the metal spacer. It's a piece of scrap I had, cut like the original spacer, and about the thickness of the washers. |
Dr Evil |
Nov 13 2007, 06:56 PM
The shim is not required with the one that Paul and I have so far as I could tell.
bbrown |
Nov 14 2007, 10:40 AM
Member Group: Members Posts: 92 Joined: 23-December 04 From: ohio Member No.: 3,330 |
Can you guys provide contact information. Thanks.
PRS914-6 |
Nov 14 2007, 10:47 AM
stateofidleness |
Nov 14 2007, 11:57 AM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
great discussion!
not to sound dumb but ive had people tell me my car doesnt start at times because my solenoid "sticks"... is $119 cheap enough security to just replace the entire starter? and that new starter has a new solenoid on it correct (noob question) the ebay listing starter, does it need any kind of spacers or anything, or is it a direct bolt-on? may consider it anyone elses thoughts on that starter? |
PRS914-6 |
Nov 14 2007, 12:20 PM
As mentioned in the above threads, it's the same one I bought . Bolt in deal, nothing else needed.
orange914 |
Jun 9 2008, 01:03 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
o.k. you guys hve been running these for awhile now how does the Highperformnance USA
starter work out? good/bad? so far it sounds like they are good |
ThinAir |
Jun 9 2008, 01:18 AM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
See this thread. I have bought 2 starters from Highperformnance USA. One for my 3.6 and the other for a 383 high compression Chevy in my truck. No problems with either. No goofy noises when cranking, no spacers or washers. Bolt in and go...... Mine came from the same source 2 years ago and has performed wonderfully. I'd purchase the same unit from the same vendor again. |
VaccaRabite |
Jun 9 2008, 06:35 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I use one (the same model that DrEvil and URY use). When I started my motor on a the bench (without plugs, just to build oil pressure) there were no undue sounds. No dragging or clacking. In fact, everything was so smooth I was not sure if the starter even engaged. I was not sure until I walked around to see the fan turning.
Zach |
Lavanaut |
Jun 9 2008, 11:31 AM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
I put one of the Nippondensos on my car last summer ~ works great, no spacers required.
PeeGreen 914 |
Jun 9 2008, 12:44 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Nippondenso is a good company. That's one of the reasons Honda and Toyota have been so successful. They use good parts to keep their engines going.
Lo-Fi Version | Time is now: 10th June 2024 - 02:24 AM |
