Fuel Injection woes |
G e o r g e |
Nov 12 2007, 03:14 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
OK
here my problem, I'm trying to use my previously functioning L jet system to break in my fresh rebuild, before i switch to an sds system. fyi I had removed everything from the engine bay for paint so everything is a fresh reinstall. which I'm sure is where my problem lies. I have spark, compression and fuel pressure, but no fuel coming from my injectors. I have checked my wiring over and over, and believe i am correct. I ,for the sake of argument, am a neophyte at best when it comes to this so any and all direction is appreciated. my ??? what causes the injectors not to fire ? is there a spot on the net that actually shows ( pics, diagrams)of the fuel injection harness connections? Where do I begin to test to get this system up and running? I would switch to sds, but the switch will be easier with the engine timed and able to idle as i work out the initial bugs. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:51 PM |
