Type IV valve cover issues...leaky SOB's |
Mueller |
Mar 18 2003, 11:20 AM
After doing a valve adjustment on my "loaner" 2.0, I installed the valve covers with brand new cork gaskets. Fired the car up last night and the passanger side cover leaks like someone opened a faucet. Is there a sure fire method to insure the gasket does it's job???
Could my cover be tweaked? |
MarkV |
Mar 18 2003, 11:28 AM
I always seem to have the same problem w/ the passenger side. In my case the gasket slips off the cover and into the head. I started gluing the gasket to the valve cover w/ 3M yellow weather-stripping adhesive and that solved the problem.
Mark 73 2.0 |
echocanyons |
Mar 18 2003, 11:41 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I assume that they could warp like the 356 valve covers.
When that happens they should be replaced or they will leak like crazy |
echocanyons |
Mar 18 2003, 11:42 AM
To tell for sure put the cover on with no gasket and if it rocks from side to side then replace it.
Lawrence |
Mar 18 2003, 12:33 PM
Yep.. a couple of VERY small dabs on the inside of the cover will help keep your gaskets in place.
I saw a set of valve covers with about 6 small tabs tack-welded on the inside to hold the gasket in place. I thought that was a nice trick. -Rusty |
Mike D. |
Mar 18 2003, 01:02 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,444 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
It's a conspiracy! "THEY" are actually making our left side gaskets thinner to save money and make us buy more Oil! - Those Bastards!
-Just kidding - (IMG:style_emoticons/default/biggrin.gif) I have rolled up pieces of tar paper and put two on each side, just under the clip and against the cover. It makes the cover tighter. Well, It worked once. Ask me after the next valve adjustment. -Mike D. |
porschewiz |
Mar 18 2003, 01:12 PM
Newbie Group: Members Posts: 29 Joined: 11-March 03 Member No.: 412 |
You may want to be carfull with making wedges, the valve cover retainer springs "click" over locks to keep the springs over the valve covers. If your valve covers arnt warped you're spring may be weak. However, normally its just a matter of keeping the valve covers in the track around the edge
Mueller |
Mar 18 2003, 01:21 PM
Are silicon gaskets available like they have for the 911's?
Mar 18 2003, 01:27 PM
914 Idiot Group: Members Posts: 14,974 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Even if they are, they won't do squat if they wind up inside the rocker box. Chances are, this is what has happened. Go take a look, Mike!
--DD PS--you gonna be at the "do" on Thursday? Want your $$ there? |
Mueller |
Mar 18 2003, 01:39 PM
Hey Dave...
Yep...I'll bet there Thursday night.....someone has to give Jereon a bad time (IMG:style_emoticons/default/smile.gif) |
Zeke |
Mar 18 2003, 01:41 PM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
Yes, there is a "rubber" gasket available. Check your local Foreign Auto Pats Store. (FAPS) Hah!
Mueller |
Mar 18 2003, 01:48 PM
Hey Zeke,
No luck at my local VW repair place.........I've gone there to get the cork gaskets and he is out entirely or only has one in stock.....no matter what I ask for, he never has it, or only has half of what I need to get the job done. How this guy stays in business is beyond me...he never has anything Type IV in stock and if he cannot find it in his Empi book forget about it. Thanks,I'll start seaching on the 'net for this type gasket |
Mar 18 2003, 03:47 PM
The all-rubber ones don't work that well, from what I have heard. I've always used the rubber-and-cork ones, and they work fine as long as they stay in the cover and the cover is not warped.
I will say it again--pop the cover off and look before you go spending more money on stuff you don't need! --DD |
anthony |
Mar 18 2003, 04:23 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
The guys at my local air cooled VW shop recommended Gasgacinch for gluing the cork gasket to the cover. Looks like this:
http://www.cbperformance.com/catalog.asp?P...?ProductID=1074 It's worked great for me - no leaks. |
Brad Roberts |
Mar 18 2003, 04:43 PM
Glue the gasket to the cover Mikey. After you get the bail clip on.. make sure to pull the cover back down. When flipping the clip back up it send the cover too high on the head. You must physically pull it back down.
Also: Make sure that all of your hoses are connected to the air cleaner for the breathers. B |
cha914 |
Mar 18 2003, 04:58 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
This is a trick that Mr. Raby told me for this problem...
Use ultra grey RTV and put a THIN coat on both sides of the cork gaskets and let it hang dry for 20min, it will be tacky at this point...then set it in the cover and when you put the cover back on make sure the VW symbol on the cover is UPSIDE DOWN ... this places the tab on the cover near the bottom of the head and keeps the cover from riding up like Brad described earlier... I have used this method for about 1.5yrs now on three different engines and havent had a leak since...plus if you are careful when removing the covers for the next valve adjustment you can reuse the gaskets... HTH, Tony |
Brad Roberts |
Mar 18 2003, 05:03 PM
Tony is dead on.
I run the VW logo upside down and didnt even think about it until he said something (I went outside and looked on a car that I just adusted valves on) I still grab them and move them around to make sure they are centered. I'm not sure that I like the idea of goop on both sides. I dont want to clean the heads if any of it sticks to it. B |
Mueller |
Mar 18 2003, 05:05 PM
great.....I went out of my way to ensure that I mounted them with the VW logo right-side up (crawled out from under the car, hit my head and looked for one of my motors with a valve cover still on it, LOL)
brant |
Mar 18 2003, 05:07 PM
914 Wizard Group: Members Posts: 11,584 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
2 tricks I have been using for the last 5 or 6 years...
1) I too use the ultra grey.. nothing else... I only use it on the the cover side.. allow it to set before installation. 2) I only use the napa brand gasket.. I don't know who makes it for them.. but this gasket is thicker than the others (even than the mail order ones I have gotten in the past).. I've been using the napa brand for years now. I used to run an accusump and would always blow a gasket after a .. ummm... situation... (spin which killed the motor and dumped 3qts, extra into my 10+quart system).. I even went to the bolt on aluminum covers (which are not necessary)... honest.. just go with the ultra grey and napa gaskets.. brant b |
Brad Roberts |
Mar 18 2003, 05:13 PM
Brant,
Do the NAPA valve covers gaskets have rubber in the cork ?? I grab whatever is on my shelf. I really dont have a valve cover gasket issue and I reuse them 3-4 times. B |
Lo-Fi Version | Time is now: 28th March 2024 - 05:27 AM |
