what is this ting on, my spare 037 djet harness? |
jimkelly |
Nov 23 2007, 11:50 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
is it a 2.0 item ??
sixnotfour |
Nov 23 2007, 12:08 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
1.8 injector resistor pack
I think |
TravisNeff |
Nov 23 2007, 12:11 PM
Looks like a bus harness or a 1.8 harness
Resistor Unit (Also called the "Series Resistance Block")- Genuine Bosch The Resistor unit is located in the left-hand side of the engine compartment, on the fuel tank compartment cover, just above the Fuel Pump (Combi) Relay. A portion of it, through the FI wiring harness is connected to terminal 88b of the Fuel Pump Relay and helps control the resistance in the FI electrical system. An item that doesn't fail too often and when it does it's usually from an overheated engine compartment. Not used on 1979 California Models, the resistance is built in to the harness and ECU on those models. 022-906-079 1975-1978 All States, 1979 Federal $113.00 http://www.bus-boys.com/bb13374.htm I also found the part on AA's site, "resistor on battery carrier" 1.8 Description Of Product: This is the device that adds resistance to the power going to the injectors to fire them. Often a wire connector breaks and they are very difficult to recrimp (you may try soldering first) or the battery acid renders it useless. Replacement is virtually a plug in and screw on affair. Fits all 914 1.8 models. |
jimkelly |
Nov 23 2007, 12:15 PM
http://www.914world.com/bbs2/index.php?sho...mp;#entry969732
jeff agrees with you guys i need to go thru all my spare harnesses to see which of te 6 types of djet harnesses i have. jim |
Bleyseng |
Nov 23 2007, 02:05 PM
I'll take it off your hands for my 2.0L Ljet Westy! (IMG:style_emoticons/default/KMA.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 06:20 PM |
