Orange 75 project, Clutch and Shifter setup |
my928s4 |
Nov 25 2007, 03:13 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
So a couple months back I posted about getting a hold of the project candidate,
feel like I have moved on from that so thought it I would post some pics on progress and I will add to this thread as time (and progress) goes on. I did not get around to stripping the car down till earlier in the month as I drove my 928 down to Sharktoberfest in LA and I was performing last minute tinkering before the drive. Anyway back to 914 subject matter, the good news is I have not found too many issues which is a relief and I can start to order parts and make some investment in tools. It is a perfect time of year for indoor projects as it is below freezing all the time now and skiing does not start here till after xmas. Surface rust and dirt in the front trunk but that is about it, will need to repiar a couple of areas around the hood seal. Chris |
3d914 |
Nov 29 2008, 03:49 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Chris,
Excellent job, and you're making great progress. I have all of the above responsibilities (plus school) and haven't made near the progress you have. Good job. Plus I keep getting distracted building the V6 engine I'm planning to install. I am curious about a couple of things. What type of citrus paint remover are you using? I tried one of the Por products - it works OK, but not great. Plus it has nasty fumes. Also, where did you find the replacement rear jack points? I need to replace both mine too. I think the PO - or whoever stole the car then - ran this thing over numerous parking curbs or something. Keep up the great job! Enjoy! |
my928s4 |
Nov 29 2008, 04:49 PM
I am curious about a couple of things. What type of citrus paint remover are you using? I tried one of the Por products - it works OK, but not great. Plus it has nasty fumes. Also, where did you find the replacement rear jack points? I need to replace both mine too. I think the PO - or whoever stole the car then - ran this thing over numerous parking curbs or something. Citrus paint remover is "Citrastrip" from HomeDepot, I got luckyI guess as it works great on paint and the fumes are OK. Comes in a spray can and is inexpensive to boot. Will not work on undercoat though. Rear jack points are from RestorationDesign. Good luck with your project ! Cheers Chris |
Lo-Fi Version | Time is now: 8th May 2024 - 08:11 PM |
