Orange 75 project, Clutch and Shifter setup |
my928s4 |
Nov 25 2007, 03:13 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
So a couple months back I posted about getting a hold of the project candidate,
feel like I have moved on from that so thought it I would post some pics on progress and I will add to this thread as time (and progress) goes on. I did not get around to stripping the car down till earlier in the month as I drove my 928 down to Sharktoberfest in LA and I was performing last minute tinkering before the drive. Anyway back to 914 subject matter, the good news is I have not found too many issues which is a relief and I can start to order parts and make some investment in tools. It is a perfect time of year for indoor projects as it is below freezing all the time now and skiing does not start here till after xmas. Surface rust and dirt in the front trunk but that is about it, will need to repiar a couple of areas around the hood seal. Chris |
my928s4 |
Mar 16 2009, 09:42 PM
One things for sure Chris, you aren't afraid of work. That upside down scraping and stripping and wirewheeling is hard work. I've done several bottoms, dune buggys, vw sedans, jeep and chev pickups, international harvestor scouts and such and it doesn't get easier with each one. I think I will try a rotisserie I built a few years ago on the 914. I'm almost 65 and maybe it will finally get easier if I go that way. I think a rotisserie would be a great idea, no doubt. Work smarter not harder, right ?! Chris, I have the HF bead blast cabinet and am using glass beads but do not clean up near as nice as yours. What media are you using? Al. Al, I use the same stuff you probably do HF Glass Beads although the ability of the cabinet to keep the stuff inside is limited. I really need to empty it and seal it. For a while I did suffer from a lot of dust then read that >80psi just turns the beads to dust, turning down to 70 worked much better. |
Lo-Fi Version | Time is now: 28th March 2024 - 03:35 AM |
