Orange 75 project, Clutch and Shifter setup |
my928s4 |
Nov 25 2007, 03:13 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
So a couple months back I posted about getting a hold of the project candidate,
feel like I have moved on from that so thought it I would post some pics on progress and I will add to this thread as time (and progress) goes on. I did not get around to stripping the car down till earlier in the month as I drove my 928 down to Sharktoberfest in LA and I was performing last minute tinkering before the drive. Anyway back to 914 subject matter, the good news is I have not found too many issues which is a relief and I can start to order parts and make some investment in tools. It is a perfect time of year for indoor projects as it is below freezing all the time now and skiing does not start here till after xmas. Surface rust and dirt in the front trunk but that is about it, will need to repiar a couple of areas around the hood seal. Chris |
scotty b |
Dec 30 2007, 05:18 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
rear pan section is definitely needed. IMHO that small area in front of the seat mount does not warrant a new pan section. You picture doesn't show any real damage there and I would recommend at the most making a small piece of metal to replace there instead of the cost and werk of a pan section.
my928s4 |
Dec 30 2007, 07:13 PM
rear pan section is definitely needed. IMHO that small area in front of the seat mount does not warrant a new pan section. You picture doesn't show any real damage there and I would recommend at the most making a small piece of metal to replace there instead of the cost and werk of a pan section. Thanks Scott, appreciate the input. There are two small pin holes in the front pan and the rest of the metal in the first indent is pretty thin but as you suggest it does seem a waste to get a new front pan for that small area. |
Lo-Fi Version | Time is now: 26th April 2024 - 10:01 AM |
