N.014.139.5, Engine Sheet Metal Screw |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
McMark |
Nov 25 2007, 04:10 PM
These pan-head screws are used to hold the engine tin in place. This part number is for the 6mm x 1.0 mm thread x 12mm long screws. Some screws are specified to be 10mm long, but 12mm screws would be satisfactory replacements.
Available from McMaster-Carr in a 100 pack, P/N #91460A318 QUOTE Metric Cheese Head Slotted Machine Screw Zinc-Pltd Steel, M6 Size, 12mm Length, 1mm Pitch Also available from McMaster-Carr in a stainless steel version, P/N #91613A420 QUOTE Metric Cheese Head Slotted Machine Screw 316 SS, M6 Size, 12mm Length, 1 mm Pitch Keywords for search: cooling tin, cheese head, cheesehead, panhead, pan head Attached image(s) |
Pat Garvey |
Nov 26 2007, 08:30 PM
Mark,
I'm scratching my head over this because I have almost all of my original screws in place on the tin. About half, or more, of the upper engine tin screws are cheesehead with a cad-type plating & the are "phillips" type. There are plenty of pan head screws all over the car & some in the engine compartment (mostly underneath tin pieces). The pan head (slotted) screws are not cad plated. ?????? Pat |
McMark |
Nov 26 2007, 10:44 PM
Hmmm, of all the engines I've touched (teardown, inspection, removal, etc) I can definitively say that the majority of tin screws have been clear zinc plated slotted screws. I wonder where your phillips head screws came from... (IMG:style_emoticons/default/confused24.gif)
I don't doubt your originality, but my experience does contradict it. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 09:05 AM |
