pic request: 72 1.7 fuel injection stuff, fuel pump and ecu |
slackin' at work |
Nov 26 2007, 07:00 PM
i should be working Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
I would like to get a picture of the fuel pump/filter area for a 72 1.7.
also need a picture of ecu mounted. where and how it is mounted would be great. car was switched to carbs and I have NO idea exactly where this stuff goes. generally I know... but this will help me out. thanks guys. (IMG:style_emoticons/default/beerchug.gif) |
swl |
Nov 26 2007, 08:34 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
I don't think I have any pics of the two but if you have a haynes there should be some reasonable ones there. The ecu mounts to a bracket on the forward facing edge of the battery tray.
The fuel pump and filter is almost directly below that on the underside of the car. The fuel pump bracket has a rubber mount to the inner fender right at the firewall. The fuel filter is supported by a two finger bracket just behind the pump. The three port fuel pump is very expensive and a lot of them are now failing. A lot of people have converted to two port pumps and mounted them up in the front trunk the way they were in the late cars. |
Bleyseng |
Nov 26 2007, 10:12 PM
ECU off battery tray
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:56 AM |
