Brazing: How do you get rid of it?, on the trunk pivot... |
swood |
Jan 2 2004, 04:51 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I'm having a tough time removing the pivots. How do you get rid of the brazing? I found more of it used in the trunk to fill a small rust hole.
I don't want to grind too much in case I cut through the sheet metal, and the grinder wheel (4.5") is too big to get the rear side. Suggestions? Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:59 AM |
