Aux. air regulator lubrication?, Repaired the AAR and wonders if any lubrication is needed |
Challe |
Dec 4 2007, 03:59 PM
Member Group: Members Posts: 60 Joined: 25-September 07 From: Sweden, Europe Member No.: 8,149 |
I found information here how to restore my Aux.air regulator and I finally get it to work, now I will seal the parts together and wonders if any lubrication is needed and if so wich type of lube?
My other question is if the heater in the bottom really should be heating all the time the motor is running? I got a lot of pictures of the process so I will write a tech faq regarding the AAR in swedish to my blog and would like to do an techarticle in english for this great community but in that case I need someone to correct my english (IMG:style_emoticons/default/dry.gif) |
blitZ |
Dec 4 2007, 06:32 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I sprayed a little white lithium grease on mine.
jim_hoyland |
Dec 4 2007, 09:01 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I take mine out once a year and do a time-to- close test. Then give it a quick spray of WD40. Time to close has not changed the past three years.
jesiv |
Dec 20 2007, 09:18 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Lo-Fi Version | Time is now: 18th May 2024 - 05:05 PM |
