Early 911 center caps, will they fit? |
blitZ |
Dec 18 2007, 10:35 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Will center caps from an 80's 911 Fuch fit a 4 lug Fuch?
warrenoliver |
Dec 18 2007, 12:00 PM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
Will center caps from an 80's 911 Fuch fit a 4 lug Fuch? Here is some useful info I got a while back. This is from SMG914 - I don't know how to do the "clicky-linky" thing, so I just "cut and paste". I hope it helps. Warrenoliver Sahara Beige Steve Group: Members Posts: 888 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 It took me quite a bit of time to compile all this data but I thought I would do my good deed of the day and pass it on to everyone here on the web site. I realize there is one discrepancy with part # 911.361.020.42. The rear 8X15 Fuchs on my M471 GT are part # 911.361.020.42 but somewhere along the way I was told that this same part number was on someone’s 7X15 Fuchs but I really thing this is wrong. 901.361.016.00 5.5X14 46mm offset, 67-71 911 T/E & 914-6 911.361.016.10 5.5X14 46mm offset, 67-71 911 T/E & 914-6 901.361.012.01 4.5X15 42mm offset, ‘67 911S 901.361.012.04 5.5X15 42mm offset, ‘68 911S 901.361.017.00 5.5X15 (MAHLE, 9.9 lbs.) ‘70-‘71 911T & 914-6 901.361.012.03 6X15 36mm offset, early 6R wheel 901.361.012.06 6X15 36mm offset, ’69-’71 early deep dish 911.361.020.00 6X15 36mm, ‘72-‘73 (3-prong center cap) 911.361.020.10 6X15 36mm, ‘74-‘77 (ring type center cap) 901.361.012.05 7X15 49mm offset, deep dish, 911R 911.361.020.01 7X15 23.3mm offset (2.7RS)(3 prong center cap) 911.361.020.11 7X15 23.3mm offset (73-77carrera)(ring type cap) 911.361.020.41 7X15 23.3mm offset (911SC) 911.361.020.42 7X15 23.3mm offset 911.361.020.02 8X15 10.6mm offset 911.361.020.12 8X15 10.6mm offset (ring type cap) 911.361.020.42 8X15 10.6mm offset 911.361.020.03 9X15 3.0mm offset 911.361.020.06 9X15 3.0mm offset 911.361.020.05 11X15 46mm offset, 911RSR -------------------- 1971 Tangerine 914-6 GT M471 1973 Sahara Beige 914 2.0 1974 Black Lotus Europa Special JPS |
Brian_Boss |
Dec 18 2007, 01:44 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
The prong type will fit on the wheels but the wheels can not then be mounted on the front of the car. The bearing dust cap extends through the wheel on a 4 lug 914 while that of a 911 or 5 lug 914 does not.
blitZ |
Dec 18 2007, 01:48 PM
I see, they may not fit. I came across a deal on some black 911 caps with the embossed Porsche emblem, thought they would look slick.
Thanks |
Lo-Fi Version | Time is now: 25th May 2024 - 02:01 AM |
