My nuts are stuck!!, How to remove nuts from studs...... |
crash914 |
Jan 4 2004, 03:56 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Ok, I pulled the engine, yanked one head, then, when removing the other, 3 of the top studs unthreaded from the block....
How do you remove? I was thinking about taking the grinder to the stud..but... Vice grips? Torch? BFH???(just had to throw that in... thanks, herb |
type47 |
Jan 4 2004, 05:04 PM
double nut the other end and use pb blaster on the stuck nut
rezron |
Jan 4 2004, 07:57 PM
Member Group: Members Posts: 327 Joined: 25-December 02 From: Mason City, Iowa Member No.: 10 |
Jan 4 2004, 08:55 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Herb,
If you are removing the pistons and cylinders at the same time, pull the cylinders off with the heads and the studs. If not, clean the threads, locktite on the threads and thread them back in....let sit over night and double nut the stud. If you dont have room to double nut it, try to tighten it a little bit then back it off... If not, take the cylinder out with it, it gives you more room to work. If you get stuck let me know. Rich |
McMark |
Jan 4 2004, 09:10 PM
You can use vise grips and heat.
Lo-Fi Version | Time is now: 27th May 2024 - 02:00 PM |
