FI wiring question |
Dec 27 2007, 08:57 PM
I have Djet, the first version of the harness, leter 72.
I have the rubber boots on the injector plugs that have two issues. They are broken They suck at holding the injectors wires in place. Can I swap the connector off the end of the later 2.0 liter harness and put it onto the early wiring harness? By this I mean. Can I use a little tool to unclip the wires and pull the wires out (with the little metal end in place) and then do the same thing to the 2.0 liter plug end. Then take the 2.0 liter snap on plug end and insert the wires (with the metal ends in place) into the newer connector ends? |
Lo-Fi Version | Time is now: 19th May 2024 - 02:53 AM |
