Transmission Seal Removal, Input Shaft |
solex |
Jan 1 2008, 01:50 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
How do I get the input shaft seal out of the transmission? The input shaft gets in the way of applying an leverage.
Thanks, Dan |
KaptKaos |
Jan 1 2008, 01:55 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
solex |
Jan 1 2008, 02:01 PM
Joe,
I'm just replacing the seal, the transmission is still together and I do not have plans to take it apart. Thanks, Dan |
KaptKaos |
Jan 1 2008, 02:16 PM
Just the input seal?
I did all of mine when I resealed it. You know "while you're in there." I am pretty sure I pushed it out. The question becomes, how do you press it back in with the input shaft there? Assuming you get the old one out, how will you make sure you get the new one in right? That's why I think I did mine with the input shaft out. Others will know better than I. |
McMark |
Jan 1 2008, 02:31 PM
914 Freak! Group: Retired Admin Posts: 20,177 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Get a seal puller.
(IMG:http://www.eurocarparts.com/sealey/images/AK7000.jpg) Cheap and available at any parts store. |
solex |
Jan 1 2008, 02:48 PM
Get a seal puller. (IMG:http://www.eurocarparts.com/sealey/images/AK7000.jpg) Cheap and available at any parts store. This tool is what I'm using and am having difficulty getting leverage with the input shaft in the way, I guess I have to try harder. Thanks, Dan |
McMark |
Jan 1 2008, 02:51 PM
You really need to jam the hook in there deep. Just be careful not to push the seal inside. It's one of those things that is tricky the first time, but each time is gets easier.
ejm |
Jan 1 2008, 04:05 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,686 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
(IMG:style_emoticons/default/agree.gif) That seal can be really difficult to remove. Be careful not to gouge the mainshaft or the case.
911quest |
Jan 1 2008, 04:39 PM
Member Group: Members Posts: 277 Joined: 26-March 06 From: Louisville Ky Member No.: 5,773 Region Association: South East States |
The seal puller works great but you can also screw a sheet metal screw into the seal and use pliers to pull it out.
TimT |
Jan 1 2008, 10:42 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
QUOTE screw a sheet metal screw into the seal and use pliers to pull it out. or a slide-hammer..... Ive done that more than once |
wertygrog |
Jan 1 2008, 11:02 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
seal puller worked for me! Just be real careful tose. not gouge the tranny case...
Cap'n Krusty |
Jan 2 2008, 12:32 AM
I've used a long 1/4" flat blade screwdriver successfully for about 40 years. The Cap'n
racunniff |
Apr 5 2008, 10:55 PM
volt914 Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains |
QUOTE screw a sheet metal screw into the seal and use pliers to pull it out. or a slide-hammer..... Ive done that more than once (IMG:style_emoticons/default/agree.gif) That's how I did it today. The "seal" actually is largely metal - drill a pilot hole (being careful not to drop metal shavings into the guts of the tranny) then insert a screw on your slide hammer, bang, bang, and it pops right out: Installing the new one is as simple as finding a piece of pipe the right size to use as a drift: Per Dr. Evil in a different thread, you just need to get it in far enough that the release bearing guide tube can be installed flush. Like this: |
Lo-Fi Version | Time is now: 28th March 2024 - 11:52 PM |
