Always pressure test oil coolers..., even suposed new ones |
Mike D. |
Mar 19 2003, 01:28 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I am doing an engine swap for a customer, 1.7 to 2.0. He brought in a hand full of new goodies for the 2.0, one of which was a "new" oil cooler that he got off e-bay. Well, like a dumbass I just installed it with out checking it.
Yesterday I started the engine, which runs great BTW, and oil just started pouring out of the cooler. (IMG:style_emoticons/default/mad.gif) I removed the cooler last night and checked it with compressed air. The air comes out almost as fast as it goes in. Needless to say I will never do that again, learned my lesson. I will always check oil coolers, new and used. Damn! Mike D. |
Brad Roberts |
Mar 19 2003, 01:31 PM
I have a fixture around here somewhere that I use to test them.
Hey... have the other Mike call me. I'm starving LOL B |
Mike D. |
Mar 19 2003, 02:16 PM
hey Brad, I have a check for you. E-mail me the new address so I can get it in the mail.
What is the fixture you use to test coolers? I just cover one hole with a thick piece of rubber, and use my air gun, it has a rubber tip, in the other hole. I found a new one for $95. I'll still test it... -Mike D. |
cha914 |
Mar 19 2003, 02:33 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
I have had the same thing happen to me...I found out that a local vw shop has used coolers that they will pressure test and sell for about 30bucks...pretty nice.
I had him test it right in front of me and the fixture was the oil cooler mount removed from the case with an air line and a guage hooked into it...so you just screwed on the cooler normally and attached an air line...at least thats how I remember it (IMG:style_emoticons/default/tongue.gif) Tony |
Mike D. |
Mar 19 2003, 03:07 PM
I bet I could make one with a hunk of billet aluminum.
Mike's Air Cooled Cooler Tester © - copyright 2003 $79.99 - (IMG:style_emoticons/default/biggrin.gif) |
kafermeister |
Mar 20 2003, 07:14 AM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
How much pressure should a cooler be able to take?
Rick |
TonyAKAVW |
Mar 20 2003, 05:23 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
According to the manual, 85 lbs.
I just had mine checked today and its bad. (IMG:style_emoticons/default/sad.gif) On the other hand that means I found the leak (IMG:style_emoticons/default/smile.gif) The manual also says to check the pressure relief valve, if there are leaks, and especially if the cooler has popped. Though with the cars as old as they are now, its a wonder the coolers stay together at all. -Tony |
Lo-Fi Version | Time is now: 25th April 2024 - 11:23 PM |
