Towing backwards... any hints? |
TonyAKAVW |
Jan 6 2004, 05:47 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I'm planning on towing a roller home tonight on a dolly that has no tranny or engine. Because of this, the axles will flop around and cause problems. My plan is to tow it backwards on the dolly. I'm not sure if the steering wheel lock works, but if it does not, does anyone have any suggestions on how to achieve a steering wheel lock? I was thinking of fixing the steering wheel itself by means of a lever, but I'm wondering if there's an easier way that I could do at the rack, etc. Or would it be easier to remove the axles and tow it
forwards? I've never done it so I don't know whats involved with that. Thanks Tony |
Mueller |
Jan 6 2004, 05:58 PM
You could tie up the steering wheel with the seat belts, then put one end of the seat belt in the door to keep it tight.
make sure the rear trunk is locked, even then, I've heard of them opening while the car is towed backwards........... |
Lo-Fi Version | Time is now: 16th May 2024 - 11:27 PM |
