Towing backwards... any hints? |
TonyAKAVW |
Jan 6 2004, 05:47 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I'm planning on towing a roller home tonight on a dolly that has no tranny or engine. Because of this, the axles will flop around and cause problems. My plan is to tow it backwards on the dolly. I'm not sure if the steering wheel lock works, but if it does not, does anyone have any suggestions on how to achieve a steering wheel lock? I was thinking of fixing the steering wheel itself by means of a lever, but I'm wondering if there's an easier way that I could do at the rack, etc. Or would it be easier to remove the axles and tow it
forwards? I've never done it so I don't know whats involved with that. Thanks Tony |
zehrschnell914 |
Jan 8 2004, 01:54 AM
Member Group: Members Posts: 93 Joined: 24-December 03 From: Portland, OR Member No.: 1,467 |
When you tow a car with the front wheels on the ground, you need to use a rope and tie off the steering wheel. You do this by running the rope around the wheel and one of the spokes and then hold it by the ends from outside the car and close the door so that the rope is tight inside and holds the wheel in the position you want it. Then tie a square knot tight up against the window so that it won't loosen up. Don't worry, it won't hurt the car. I've used this setup hundreds of times back when I drove a tow truck. There will be a little play, but it should trail fine. Even if the steering lock is working I would still use the rope. Good luck.
Lo-Fi Version | Time is now: 17th May 2024 - 12:31 AM |
