Relay terminal sleeve housing, wire removal for relocation help |
G e o r g e |
Jan 16 2008, 08:15 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
ejm |
Jan 16 2008, 08:32 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The terminals have a tab that keeps them from sliding out of the housing. Looking from the relay side, the plastic housing has a small slot behind each terminal. Use a thin screwdriver down the slot to press the tab and slide the terminal out. It becomes easy after the first one. (IMG:style_emoticons/default/smile.gif)
G e o r g e |
Jan 16 2008, 08:46 PM
thanks, thats what i thought, I guess I'm taking it to easy
Lo-Fi Version | Time is now: 17th May 2024 - 07:14 PM |
