The 170 HP MassIVe 2056cc beast, And it only has 9:1 CR, video links within! |
Jake Raby |
Jan 28 2008, 08:32 AM
Thats right...
We have just broken RAT history again and have exceeded our expectations on the very first pull from a recently developed 2056 combo using a cam that was developed in 2006 and a set of off the shelf LE 200 heads! This engine was originally going to be equipped with our roller lifters, but due to continued challenges we had to scratch the rollers and apply conventional lifters to the engine. The power we have made with this engine using the conventional lifters is basically the same or just a tad more than we were looking for with the rollers, so I am VERY happy. The graph posted below is from the engine's VERY FIRST pull and we know this combo has more potential that will be found in tuning alone as we continue to understand how the combination functions. Now, the most amazing part of this is the fact that this engine absolutely annihilates the best 2270 combos from 2-3 years ago in every way! It makes just as much torque, and more HP that our 9:1 Performer 2270 did in 2006! Last week Charles from LN engineering came down for another round of oil testing and we used this engine for the analysis. After testing 11 oils we decided to pull the heads back off the engine to see if Len can find even more power. We'll have the heads back this week and will get more results. I honestly expect 190 HP from this engine with the changes Len will make and the CR we plan on adding. At 9:1 this engine would run easily on 89 octane and based on the timing settings the engine liked it will love 9.5-9.8:1 CR You can view a short video we threw together from the oil testing on youtube here http://www.youtube.com/watch?v=FYV8OD8Ohlg&feature=user This one is just days away from being added to my turn key engine catalog... This may be the best cost/HP engine we have ever created and it still has great torque! |
Jake Raby |
Jan 28 2008, 08:44 AM
rhodyguy |
Jan 28 2008, 09:01 AM
wow agin!! 44s with 32 vents, tall mainfolds and a mallory?
Jake Raby |
Jan 28 2008, 09:04 AM
Nope, off the shelf 45 Dellortos and tall manifolds..
The short manifolds will more than likely give us too much top end and sacrifice torque. I want to retain this torque or capitalize on it!! |
Bleyseng |
Jan 28 2008, 09:06 AM
How would this combo do with the twin TB'S?
Trevorg7 |
Jan 28 2008, 09:07 AM
Senior Member Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region |
Very cool!
Congrats T |
Jake Raby |
Jan 28 2008, 09:20 AM
This cam has carburetor characteristics.. More than likely FI would HURT this combo's power..
rhodyguy |
Jan 28 2008, 09:21 AM
i'm Del ingnant. how do the 45s compare to a set 44s configed as i mentioned? my guess is a tangerine is bolted up. if you were ever so inclined, i'd find it interesting to see a test for those that don't have the scratch for one of chris' systems and run 2.0 ss hes and a performance exhaust, or a powerplant designed for them.
k |
Pnambic |
Jan 28 2008, 10:01 AM
Honk if you like obscene gestures! Group: Members Posts: 914 Joined: 9-April 03 From: Atlanta, GA Member No.: 546 Region Association: South East States |
QUOTE i'm Del ingnant. how do the 45s compare to a set 44s configed as i mentioned? my guess is a tangerine is bolted up. if you were ever so inclined, i'd find it interesting to see a test for those that don't have the scratch for one of chris' systems and run 2.0 ss hes and a performance exhaust, or a powerplant designed for them. k I second this motion. (IMG:style_emoticons/default/smile.gif) |
Jake Raby |
Jan 28 2008, 10:30 AM
This engine would not be supported by Heat exchangers. The cam it uses is heavy on exhaust duration and requires an exhaust like Chris'
The 44 Weber flows 290 CFM Vs the 45 dell's 330 CFM, but a 44 weber should support the engine with ease. I'll know when I get the heads back on it with more CR and we go for round 2. |
brer |
Jan 28 2008, 11:00 AM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
sean_v8_914 |
Jan 28 2008, 11:25 AM
Jake, the end of that video cracked me up. you are having way too much fun being the engine DR/mad scientist. I bet you like the smell of brad penn. I know I do. few are fortunate enough to enjoy their job as much as us.
PS. that would make a kick butt CP engine to run in PCS AX. I think it would be no contest against a regular 2.0 carbd engine will this technology tranfer to your stroker mojos to increase their output also? |
Jan 28 2008, 12:03 PM
So, based upon those results, what would the 2270 do with a similar cam/head combo?
Rich |
Jake Raby |
Jan 28 2008, 12:20 PM
QUOTE Jake, the end of that video cracked me up. you are having way too much fun being the engine DR/mad scientist. I bet you like the smell of brad penn. I know I do. few are fortunate enough to enjoy their job as much as us. Yep.. I do have a lot of fun... The scent of Brad Penn can be noted from the tailpipe 100 feet away!! QUOTE PS. that would make a kick butt CP engine to run in PCS AX. I think it would be no contest against a regular 2.0 carbd engine No way, it has almost 100HP more than stock, not bad from less than 100ccs of added displacement!! QUOTE will this technology tranfer to your stroker mojos to increase their output also? Development with this will occur soon.. BUT there is a compromise of this cam being ran with stroke.. Thats because the lovbe lift is hefty and requires a seriously reduced base circle. the reduced B/C pulls the lifters further from their bores when on the heel of the lobe and that weakens the bores and makes for more wear... This is why I always preach that it's all in the combo, because a 2270 with this cam may make big power, but wouldn't meet my demands for longevity for the MassIVe program. That being said I'll almost bet that this cam, when used in a 2270 will make LESS power than with the 2056 and thats because bigger simply isn't better than "smarter"... QUOTE So, based upon those results, what would the 2270 do with a similar cam/head combo? I'll let the engine tell me.. Give me 45 days. |
Jan 28 2008, 12:22 PM
QUOTE Jake, the end of that video cracked me up. you are having way too much fun being the engine DR/mad scientist. I bet you like the smell of brad penn. I know I do. few are fortunate enough to enjoy their job as much as us. Yep.. I do have a lot of fun... The scent of Brad Penn can be noted from the tailpipe 100 feet away!! QUOTE PS. that would make a kick butt CP engine to run in PCS AX. I think it would be no contest against a regular 2.0 carbd engine No way, it has almost 100HP more than stock, not bad from less than 100ccs of added displacement!! QUOTE will this technology tranfer to your stroker mojos to increase their output also? Development with this will occur soon.. BUT there is a compromise of this cam being ran with stroke.. Thats because the lovbe lift is hefty and requires a seriously reduced base circle. the reduced B/C pulls the lifters further from their bores when on the heel of the lobe and that weakens the bores and makes for more wear... This is why I always preach that it's all in the combo, because a 2270 with this cam may make big power, but wouldn't meet my demands for longevity for the MassIVe program. That being said I'll almost bet that this cam, when used in a 2270 will make LESS power than with the 2056 and thats because bigger simply isn't better than "smarter"... QUOTE So, based upon those results, what would the 2270 do with a similar cam/head combo? I'll let the engine tell me.. Give me 45 days. I figured you just found some new magic and you would try it on your favorite motor...just curious if you had already done it. Rich |
So.Cal.914 |
Jan 28 2008, 12:24 PM
"Have a milk jug of oil...It's good for the heart" (IMG:style_emoticons/default/biggrin.gif)
Jake Raby |
Jan 28 2008, 01:06 PM
Yeah.. I was just goofing off with the video camera and software, trying to get as much editing experience as possible :-) |
kart54 |
Jan 28 2008, 01:25 PM
Senior Member Group: Members Posts: 544 Joined: 27-January 05 From: Ventura, California Member No.: 3,520 |
Jake,
I have to tell you, I sometimes think you are a little heavy handed in your posts but that video is great!!! It was informative, entertaining and funny. I've gained a whole new respect for you. Your personality doesn't come through in your posts in any way close to the way it does in that video. Keep up the good work! I'm anxious to see the results of this test, where can they be found? Kart54 |
Jake Raby |
Jan 28 2008, 01:48 PM
Jake, I have to tell you, I sometimes think you are a little heavy handed in your posts but that video is great!!! It was informative, entertaining and funny. I've gained a whole new respect for you. Your personality doesn't come through in your posts in any way close to the way it does in that video. Keep up the good work! I'm anxious to see the results of this test, where can they be found? Kart54 I learned long ago that people only allow things to sink in here on the forums if it is bold and firm... The video is really who I am.. You'll be seeing many, many more videos in the coming months.... |
Jan 28 2008, 02:09 PM
Interesting point.
I noticed in one of the first TV commercials for Obama that he had an aweful time looking at the camera. He kept reading the Q card and the result was he looked shifty eyed. I sent an email to his keepers to point that out. I was not the only one who noticed this...he no longer does one on one with the camera, he stopped that format all together. Point being is that we each have our own style that works best when marketing and maybe the videos are better, who knows. Rich |
Lo-Fi Version | Time is now: 18th May 2024 - 07:29 PM |
